How do you remove the steering wheel?
on
1 Post
Re: How do you remove the steering wheel?
Originally Posted by kingkub57
Also when you do get the nut loose before you pull your wheel off, put the nut back on and screw it on a few turns, you may have to wiggle the wheel some to get it loose, but when your pulling it off it wont hit you in the head.
Thanks guys I have an impact gun but it looks like I'm going to have to get the right attachment.
Doc I'm just trying to align it, when I'm driving dead straight the wheel is a little to the right, I got 2 wheel alignments done plus I checked the tyre pressure so I'm going to try and change the position of the steering wheel.
Look at this post to remove your steering wheel;
https://www.crossfireforum.org/forum/554252-post8.html
There is a discussion somewhere about the difficulty of getting these screws out, it requires a T30 Torx according to Montana Crossfire.
on
It was two torx to remove the air bag and a big allen to remove the wheel on my car
Anyone removing the wheel and adjusting it on the splines should read the Repair Manual.
