Index of Crossfire problems and repairs
Index of Crossfire problems, repairs and How Too's
Some of the information is outdated but most is still relevant.
The SEARCH feature on the forum and Google is your friend.
Moderator note: The search function here is pitiful. Using Google, do this:
On the google search page, enter: "Chrysler Crossfire __________________ " with what you want to find in the blank space.
Now, after hitting enter, scroll down to the entries google finds at www.crossfireforum.org.
You will find that the results are pretty good, google can find stuff here better than the forum's search engine.
This is an attempt to list common repairs, modifications and general information in a single thread to make things easier to find.
Crossfire Production Details.
2004 production- PDF
2005 production - PDF
2006 production - PDF
2007 production- PDF
2008 production - PDF
Production Figures - JPEG
Vin of the First and Last Crossfires made each year. PDF
youtube videos of repairs to the Crossfire by danis10fr This is in French
Service Manuals, Parts Lists, Owners Manuals, Navigation CD's etc etc.
Crossfire, NA and SRT6 documentation collection. These are on the .org site. All of the info can be found here.
Diagnostic Trouble Code Numbers -DTC(PDF)by HDDP
2006 Owners Manual - PDF
2007 Owners Manual - PDF
Official Chrysler/Mopar Accessory Installation PDFs
Signal Mirror Installation - (PDF)
Lighted door sills install - (PDF)
Crossfire Navigation radio install PDF
How to install a cargo cover - PDF
Instructions for fitting the Mopar Bra. - (PDF)
Mopar Paint Guide PDF
Mopar Heated Seat Repair - PDF
Instructions for fitting the Mopar Bra. - PDF
Official Chrysler/Mercedes PDFs
Mopar Accessories for 2007 (PDF)
Chrysler Electrical Parts List (PDF)
Mercedes Electronic Parts Catalog for the SLK320 and SLK32. Click the links.
Mopar Electrical components and locator PDF
Tips when thinking of buying a Crossfire. CLICK
Engine – Mechanical
Valve cover leak...PDF
Breather cover oil leak.. PDF
Breather cover resealing by the late MikeR PDF
Needswings Oil catch can install For the NA- PDF
74mm throttle body upgrade (NA)- PDF
Air filter replacement- NA PDF
EGR Valve Location - PDF
EGR Valve Service - PDF
Relieving Pressure on the Serpentine Belt. PDF
Engine coolant change and flush PDF
Mercedes Engine Cover, throttle body and 74mm MAF. PDF
Replace alternator/generator on SRT6 (NA similar) PDF
Solutions for P401 air pump malfunction code.
Miller Tools for the Crossfire password is 'crossfire' (PDF)
Cleaning K&N filters
Fluid Capacities NA
Camshaft position sensor PDF
Oil pan replacement M112 motor PDF
Syfi's do it yourself DCAI-1 PDF
Pulley Bearings PDF
Spark Plug Replacement PDF
Oil level sensor replacement
Engine SRT– Mechanical
SC pulley install-Code 3 shown-others the same. PDF
tighed1's Super cooler install PDF
NeedsWings SRT-6 Single Air Intake Install - PDF
SRT6 Inter Cooler pump always running method.
The oil catch can install For the SRT6
Install a Johnson IC Pump PDF
Supercharger Oil Change by 70GT6 PDF
Super Charger and Pulley Bearings PDF
SLK oil level sensor operation PDF
Secondary Air Pump repair PDF
Supercharger operating details and set up.
Super Charger pulley mods discussion.
Super Charger technical discussion.
Super Charger specs and load chart PDF from rcompart
Engine – Electrical
Sticky Ignition Key Fix (2004-2006) / Stuck Key Fix (2004-2008) - Robert McCubbin - (PDF)
Sticky Key Fix - Big Daddy video
Is my starter bad? -PDF in post #1
Engine ground cable by James1549
Mystery no start- RCM repair (PDF)
Relay replacement in RCM.PDF
Relay Datasheet in RCM.PDF
How to replace CPS PDF
YouTube video of CPS removal by Big Daddy
Chrysler Electrical Parts List PDF
Throttle Reset PDF
Alternator Replacement, SRT shown, NA similar. PDF
Alternator Removal PDF
Valeo Alternators for the Crossfire
ECU Repair by CL770
Video of the SKREEM replacement by Big Daddy.
ECU Removal - PDF by EuroCharged
ECU Repair - PDF by CL770
Secondary Air Pump Repair
Relay replacement in the RCM - PDF
Bosch Spark Plug Specifications - PDF
NGK Spark Plugs Technical Data
NGK Spark Plugs Anti-Seize PDF
Engine - Cooling
Coolant Overflow Tank Nipple Repair PDF
Engine coolant change and flush. ( PDF)
Transmission
DIY Transmission leak fix with photos... TA DAAaa
How To - Transmission Filter/Fluid Replace
Paddle Shifters Install Instructions PDF
Installing a clutch in a Crossfire PDF
Nag1/722.6 Auto transmission repairs. YouTube Video
Oil Sensor in transmission
Changing the oil sensor.
Fitting an auto shifter with a manual transmission boot
FCP Euro 722.6 transmission service
Center Bearing Hanger Replacement PDF
Transmission oil depth. CLICK
FCP Euro transmission fixesCLICK
Maintenance of Oil displays on the Dash
#1 Checking Mileage left on the FSS PDF
#2 Checking Mileage left on the FSS PDF
Checking the Oil level via the dash display PDF
Reset the FSS PDF
Brakes, Wheels, Tires, Steering and SuspensionRoll bars and Bushes
Replace your steering stabilizer
TPMS - Tire pressure sensors. by ZH SRT6 PDF
How to remove the steering wheel. by JHM2K PDF
Bedding in your new brakes
Suspension Picture Show, an Extravaganza.
Brake Specifications PDF
Change the Front Brakes on an SLK320 (Crossfire) PDF
Change Rear Brakes on an SLK329 (Crossfire) PDF
Parking/Emergency brake pads.
Speed Bleeders part numbers for NA and SRT by dedwards0323
Replacing Front Wheel bearings.
Inner and Outer Front Wheel Bearings Replacement
How to disable the TPMS system
Wheel Paint Repair
Easy way to remove dust caps on wheels
Front Roll Bar Bushings PDF
Electrical
Headlight headache...do you have water in your trunk?
"How to - Horn All of the Time"
Do you want a Keyless Entry Alert Tone?
Seat Relay-Repairing-Replacing PDF
Battery Replacement
Fob programming for door unlocking
Key Programing
Programing Garage Doors
Mopar Heated seat repair - PDF
Heated seat repair using a kit. - PDF
Seat Heater Repair - Dorman heaters and video
Blower resistor replacement - PDF)
Rebuild your key fob - PDF
Adding an Auto-Dimming Mirror PDF
Eliminating the TPMS Light on the instrument panel. - PDF
Installing the TPMS sensors. PDF
Trunk Lid jammed
factory-alarm-chirp-solved
Locking/Unlocking pump in the trunk
Headlight-headache-do-you-have-water-you-trunk
Signal Mirror Installation - PDF
Disabling the seat belt chime without cutting wires.
Replacing the batteries in the siren. PDF
Osram/Sylvania Bulb numbers for the Crossfire
Front Signal Socket Replacement. - PDF
Electric Deck lock Mod PDF
Blower motor and resistor test PDF
Security Pump CLP/SSM Diagrams PDF
Switched power stud in the underhood fuse box- by SparkieSRT6
Beeping Siren for the Crossfire PDF
Wireless backup camera installationPDF
Cigarette lighter and Glove Box light on all the time PDF by Pizzaguy
SKREEM operation PDF
Finding Battery Drain V3 by Pizzaguy
Finding Battery Drain V1 by Pizzaguy
Understanding Your Engine Fan PDF By Pizzaguy
Lighting
Auto Headlights, Fogs On With Highbeams & Other Quirks Fixed! Cigarette lighter and Glove Box light on all the time PDF by Pizzaguy
FRONT SIGNAL SOCKET - PDF
Fog Light Fix - Removing the Loose Cap PDF
Fog Lights-hiding the loose cap PDF
Adding LED lights to the footwells.- PDF
Adding LED lights to the trunk by replacing the OEM light -PDF
Installed Super Bright LED Daytime Running Lights
replacing-map-lights-LEDs
how-recolor-your-switches-lots-pictures
how-recolor-your-stereo-lots-pictures
how-recolor-your-gauges-lots-pictures
how-to-recolor-your-gauges -PDF
illuminated-sill-plates-color-change-revisited
how-replace-headlight-bulb-pictured-step-step-instructions (PDF)
Easy-way-replace-marker-lights
HID lights install - (PDF)
Fog light fix by 04Fire (PDF)
The front signal socket where to buy PDF
Fog Light, replace lens or body. PDF
Glove Box Light - changing bulb PDF
LED License plate lights - by JHM2K
Headlight bulb retainer clips - SAAB part #5400007
Trunk lighting with LEDs PDF
Cabin Foot Well lighting with LEDs PDF
Center High Mount Brake Light Repair
Map Light Repair
Headlamp Condensation Prevention Kit - PDF
Removing the license plate light fixture - PDF
Crossfire Bulbs - PDF
Wire/Amps Selection Chart
Radio
Biggest stereo bang for the buck mod
Solisto Audio 5G guide PDF
Crutchfield Master Sheet (PDF)
Becker CD Changer install
Kenwood KMR-D562BT Install by GregWork (PDF)
Crossfire radio users guide (non-nav) PDF
Becker radio wiring diagram PDF
Has radio display gone berserk?
Replacing woofers with KickersStock Radio manual -PDFStock Radio - PDF
Cabin Air Filter ReplacementPDF
Window Adjustment
Trunk lid Jammed
How to replace that pesky broken ashtray/coin holder
Replacing the cupholder with a storage bin (PDF)
Replacing cupholder with $15 Saturn bin
How-remove-center-console-how-replace-side-mirror-switch(PDF)
Sticky Ignition Key Fix - (PDF)
How to install a cargo cover - (PDF)
Cup Holder Repair - PDF
Removing chewing gum from the mats. PDFChanging Base seats to power seats.
Installing 8-way motors on a passenger seat. By Red Runner - PDF
Interior Odour Elimination.
How to change from a manual to an auto-shift cover by Beaner
Fixing hesitant power windows -PDF
Headliner, Removal and Recovering. PDF
Headliner removal YouTube video
Headliner_Removal PDF
Headliner Repair by Woody.
Doors
Window adjustment- (PDF)
How to remove door panel
Door pull repair PDF
Body
NA spoiler removal
How to replace washer reservoir -(PDF)
Headlight restoration
Headlight - Clean the inside of the lens.
Mopar Paint PDFRocker panel removal PDF
Jacking Puck Removal PDF
Hood opening on a car with a broken cable PDF
Water in the trunk by fastfunfor2 PDF
Water in trunk-SRT6 spoiler leak by 180
Fix that broken fuel door
Removing Roof trim strips.
Windshield Wiper Blade Replacement. - PDF
REAR SPOILER SERVICE PARTS AND PROCEDURES - PDF
How to open the trunk when the CLP/SSM fails - PDF
How to open the trunk when the fob and dash switch fail - PDF
Side Strake Removal
Adding the Windshield Wiper stem grommet - PDF
Roadster Body
Manual top operation - by Pizzaguy
Roadster top repair using Top Hydraulics
Roadster Roof Parts and service by Top HydraulicsRepair to Roadster rear window - PDF
Roadster Trunk Lid Lock Mod to prevent jamming
Roadster ToolHow to remove the roadster top PDF
Repair Manuals, Parts Lists, Owners Manuals, Navigation CD's etc etc.
Heating and Air Conditioner
Cabin filter replacement PDF
Blend air door problem in heater/air-con.
AC blows hot? Weird idle/lope at the start? Fixed mine!
Heater Valve repair
Air selector switch issue PDF
Heater-AC Fan Speed Control Removal and Repair PDF
Fob Repairs
How take apart key fob without destroying it (PDF)
Programming the Fob
Reset the Fob PDF
Misc Repairs to Fob.
Miscellaneous How To's
How to make your own low profile car ramps
Wheel repair - (PDF)
How to download the Navigation CD's
Remove the shift **** PDF
Reset the FSS PDF
Throttle reset PDF
How to install The Accelerated Industries one-touch switch - PDF
HowTune, how-to articles for the Crossfire
This includes;
Change the engine oil.
Replace the coolant.
Replace the headlight bulb.
Disable the TPMs bulb.
Replace the CPS.
Replace the brake bulb.
Bleed the brakes.
Bleed the clutch.
Replace the steering stabilizer.
Replace the front brakes.
Replace the rear shocks.
Replace the cabin filter.
Miscellaneous
List of MB and Crossfire part numbers
Service summary - (PDF)
Crossfire compared to other cars - (PDF)
Suppliers for Crossfire Components - (PDF)
List of resettable Crossfire features (PDF)
Comprehensive Spares list for the Crossfire. By GregWork. (PDF)
Miller Crossfire tools PDF ( Password is 'crossfire')
Mercedes OBD codes PDF
Crossfire Build Sheet by Padgett PDF
Vehicle Security and SKREEM PDF
Mercedes numbering system explained
EuroCharged Documents CLICK
Needswings Documents
Needswings Oil catch can install For theSRT6 (PDF)
Needswings Oil catch can install the NA- (PDF)
NeedsWings SRT-6 Single Air Intake Install - (PDF)
NeedsWings SRT-6 Dual Air Intake Install - PDF
NeedsWings NA Single Air Intake MAF Install - PDF
NeedsWings SRT-6 SC INTERCOOLER SEPARATION KIT Install - PDF
Search the Benz web.
Sales brochures etc.
Australian sales catalog PDF
Crossfire 2006 catalog PDF
Crossfire 2007 catalog PDF
The attached files below cannot be organized so WYSIWYG.
Engine – Mechanical
Fluid Capacities NA
Pulley Bearings PDF
Engine – Electrical
Throttle Reset PDF
ECU Repair by CL770
Engine - Cooling
Transmission
Reset the FSS PDF
Wheel Paint Repair
Electrical
Battery Replacement
Key Programing
Trunk Lid jammed
Lighting
Map Light Repair
Radio
Window Adjustment
Trunk lid Jammed
Doors
Body
NA spoiler removal
Side Strake Removal
Roadster Body
Heater Valve repair
Fob Repairs
Programming the Fob
Reset the Fob PDF
Reset the FSS PDF
Throttle reset PDF
This includes;
Replace the CPS.
Bleed the brakes.
Bleed the clutch.
Miscellaneous
wagonerca (04-28-2023)
Re: Index of Crossfire problems and repairs
check this out ... gave me great info I needed ...
Sorry .. I don't know how to do the linky thing:
DIY Transmission Leak Fix with Photos ... TA DAAaa
EDIT: Also check on tighed1 repair for the roadster rear window. It can be found on post #19 in the following:
Roadster Rear Window Problem
BTW .... a great ambitious project 180
on
Nice thread, Dave. But I'm already bored, I think I'll go and start a thread "Index of Women problems and my answer to each of them".
But before I go, don't forget my Roadster TrunkLid Jammed thread!
ht tp://www.crossfireforum.org/forum/crossfire-roadster/39283-trunklid-jammed.html
(Just remove the space between "ht" and "tp" after you copy and paste the link, I can't get the link to work.
Clean up your two posts and combine them and you will have your own single post entry here.
Kraig (01-25-2022)
Dave, how about a document that references tips for putting our cars into winter hibernation. There were alot of good ideas when I first asked. I found it really useful. Little things like putting a styrofoam block under the wiper arms to keep the blades off the windshield. It couldn't hurt and I will always do that. I'll work on a checklist if one doesn't already exist, based on searching the posts.
I really would like to see a video or photo how to that shows how the average guy can put the car up safely onto 4 jackstands.
Hmmmm ... Fiddler in a Crossfire ....
If I were a rich man,
I would own a Crossy that would never need an oil change.
All day long I'd drive it in the sun,
If I were a wealthy man.
I wouldn't need the jackstands.
Ya ha deedle deedle, bubba bubba deedle deedle dum.
If I were a biddy biddy rich,
Yidle-diddle-didle-didle man.
Nah ... the tune's just not catchy enough. Anyway, Nicholson couldn't sing it 'cause, "HE CAN'T HANDLE THE TUNE!!"
great job here 180 - More pic's for the cupholder replacement thread
https://www.crossfireforum.org/forum...placement.html
Remove Center Console/Replace Side Mirror Switch
https://www.crossfireforum.org/forum...or-switch.html
This will also help with replacing the cup holder.
on
1 Post
If you started an index on that problem the site would crash from the overload.
Has anyone out there trued to install lowering springs? I am moderately mechanical but don't want to pay the $400 that a couple of mechanics quoted me.
on
1 Post
Re: Index of Crossfire problems, repairs and How Too's
My 2005 SRT-6 convertible sits a little higher than I like so I bought a set of B & G lowering springs. I can't find anyone in the Dallas Fort Worth area that wants to install for less than $400.00. Has anyone installed these? I would think that this would be a popular mod since you can get these on eBay for $265/set of 4.
Thanks! (Note: If interested, Mercedes mech's do not recommend and thing other than the German made B&G Springs)
Eddie
Eddie
