serpentine belt replacement
Re: serpentine belt replacement
Originally Posted by Sarina
Well I gave up on the alternator since I can't seem to get to one of the bolts in the back (bottom). I did get the S-blet off and the two alternator bolts. I can't really see what else is holding it on or how to get it to come out. Oh well, I did try.
Originally Posted by tighed1
Did you look in the on manual for the procedure?
Other owners in your area. Maybe someone will lend a hand.
Or drive out here and I'll help!
Thanks so much for the offer. I do not have an owners manual for the car. It is on my list to buy along with a few other things. I guess I should have ordered it first. I did look at one I have saved and downloaded on my PC, but there is nothing about alternators in it. I did try my hand at it again (I'm a bit tenacious) and have it jacked up and secured now. I just can't seem to find how to loosen it. The two main bolts are out and I'll admit, my engine is DIRTY!! Embarassingly so. At least I know now what else to put on that wish list of mine. Anyway, I am about to go crawl back under and see just what is holding it on so tight. Could it be ther grease? Is it ok to take a rubber mallot to it and give it a few bangs of encouragement??
Is it the one you have already?
https://www.crossfireforum.org/forum...ollection.html
Follow the instructions to download files. It says SRT6 but that is not true, it is confusing and I am sure some people see that and do not bother to look at it. It may have started out as an SRT6 thread but other info is on there. It should be in the Coupe section, but nobody wants to upset the apple cart and annoy some tender souls.
Hey Mods, why not move the documentation thread to where it should be?
My instruction sheet above came from the 2004 Repair Manual which can be downloaded from this site on this forum.
Ok. Well I'm glad it wasn't me! So apparently the person who replaced the alternator to begin with tightened the bolts too far in causing the spring pin to basically mount against the alternator. Fortunately my genius husband, who is very proud of how much I did accomplish, used a piece of brass and his air gun to tap the alternator back a bit-cuz it wasn't budging. Thanks so much for all your help, guidance, and support. I was very happy with my success of removing the fan, the belt, and the two bolts (all without the use of power tools-and while cooking a fabulous dinner). Really, thanks again everyone. It's nice to have this forum group to count on.
Tighten these bolts up to spec on assembly or they may come loose.
OK, so the sleeve does not enter the alternator, it just pushes the alternator against the back mounting plate. I guess it seizes up a bit and locks the alternator in place.
Thank you all again!!! Once more you saved the day and saved us a whole lot of money.
My serpentine belt shredded yesterday while I was on the highway, taking a really deep curve to exit onto another highway.
Power steering went out, battery light went on. And of course, no where to pull over. The temperature rose very quickly to the red, so I immediately turned the heater on full blast and got the needle back down. Finally there was an area to pull over safely. Had the car towed back to the house and my husband just put a new belt on according to the directions shown here. Yay!!! You all are awesome! You have saved us thousands over the last few years!
Well...is my face red! Matches my Xfire...I thought replacing the serpentine belt was the sum of all our problems. Wrong! Turns out we have to replace the idler pulley. So it's almost fixed. Had to order the part and will pick it up on Tuesday (along with the relay for the power seats - driver seat is stuck in position for my 5'3" in height, so my 6'7" husband can't drive it at all! LOL) Now we realized the pulley was bad because we had "that whining sound" several of y'all have been describing. I'll let y'all know when it's all done.
Then I just need to find a driver side visor and the hydraulic arm that holds the hood open. After that she'll be like brand new.
Originally Posted by sa_red
Well...is my face red! Matches my Xfire...I thought replacing ..............Tuesday (along with the relay for the power seats - driver seat is stuck in position for my 5'3" in height, so my 6'7" husband can't drive it at all! LOL)
Have you checked to see if the seat will move when, a, the door is open or b, when the door is closed.
If it will work in just one of these conditions then it is a 10 cent part inside is broken but not worth fixing if the part is cheap enough.
This is a good thread! It's my turn to replace the belt... I noticed cracks on the edges yesterday while putting in a brand new Optima RedTop in the car. By the way, my optima lasted 4 years, considering all the gadgets and capacitor, that battery lasted a long time. I used a battery tender on it once for 6 months straight while I has in Iraq.
My xfire is a 2004 with 38K miles I figured its 9 years old. What else should I buy due to its age? Thanks
where did you buy your belt and how much does it cost? im lookin for low cost serpentine belts for 08 Chrysler... I tried to check online and it was $40, looking for a cheaper one... thanks
ooops, since you said an '08, it is NA ( no SRT6's that year )
RockAuto Auto Parts
discount coupon : Rock Auto Coupon Codes: Get $7 Off w/ July 2012 Coupons, Promo Codes
You should be able to get one for around $15 total ........
I have seen the post on belt removal but do not understand it. Can I simply use a 17mm to relieve the tensioner on the belt? It mentions a torex but what part does it play in releasing the belt tension?
any help will be appreciated
Also I am looking to replace the a/c clutch and it has 8 grooves instead of 6 like the regular XF. Any ideas where i can get one. The part # would be invaluable. It would be easier that just replacing the bearing. regular xf bearings and clutches are very easily located but not srt
Last edited by crossfire@srt; 08-18-2017 at 07:14 PM. Reason: need to add a thought
T
T
Has anyone had this happen? Driving normally down the interstate. AC stopped cooling, Battery Light came on. Pulled over to the shoulder quickly because I knew the Serpentine Belt must have broken.
I found the belt was laying down in front of the engine. It did not break. I looked at all the pulleys and noticed a small one in the Center Right of the front of the engine that had burnt rubber on it. This pulley would not turn. All other pulleys turned (except the Engine Crank Pulley).
I had it taken to the dealer and was informed that the Water Pump bearing failed. Just wanted to know if that pulley that is locked is part of the water pump.
Any enlightenment would be appreciated.
You can turn the water pump pulley by hand and see if the bearing is grinding.
CLICK for positions of the various pulleys and a diagram.
