$20 Cheap Fob Fix !!!
on
1 Post
http://cgi.ebay.com/ebaymotors/2-BUT...#ht_3186wt_943
Take your guts and key and place them inside this Mercedes Case For $20 You just loose the panic button and who uses it anyway?
on
1 Post
Re: $20 Cheap Fob Fix!!!!!!!!!!!!!
i tried to do so on my ml320 keys, the case is not the same and i am unable to switch over, instead i broke my oem key dissasembling it
the ebay case had a wider key and the circuit board did not fit inside.
on
1 Post
If I had my key with me I would take a pic and you could see what I have to loose or not loose to be more accurate. The chip its self is fine but the battery wont stay in so why would I want to pay 189 bucks when what I have now will lock and unlock my door just not remotely?
@ Kim- I can see you now hunkered down behind a bush snickering as unsuspecting persons pass by your car in hopes one gets to close! Haha
Re: $20 Cheap Fob Fix !!!
Originally Posted by jmk41
2 BUTTON REMOTE KEY CASE FOR 1997-2003 MERCEDES-BENZ | eBay
https://www.crossfireforum.org/forum...estroying.html
o55ie18
10-05-2015 05:50 PM
Selbyl
09-26-2015 04:15 AM
tritongreen
09-18-2015 07:32 AM
