alarm, make it work
Old 09-25-2011, 06:37 PM
johnsrt's Avatar
Default alarm, make it work
does are alarm go off when your try to open a locked door? if so i cant get mine towork
Old 09-25-2011, 06:56 PM
rekcah's Avatar
Default Re: alarm,,make it work
No, only when you actually open a locked door
Old 09-25-2011, 07:42 PM
Default Re: alarm, make it work
I am always opening a locked door, just so I can drive my car. Why would the alarm go off?
It will go off if you are inside and open the door after locking it with the remote while sitting inside. This arms the security system and sees the door opening as a reason to set the alarm off.
Old 09-25-2011, 07:43 PM
Old 09-25-2011, 08:05 PM
rekcah's Avatar
I was just too lazy to be specific. I'm guessing that the OP was asking, if you pull the outside door handle when the car doors are locked and the alarm is armed, will the alarm go off if the door does not open because the lock is fully functional? And the answer based on how my car alarm is,is "No." The alarm will go off when the door is actually opened and the alarm has not been disarmed. Just pulling on the handle will not set off the alarm if the door doesn't open.
Some possible scenarios are:
#1 Your passenger is too slow to get out before you get out, close the door and hit the lock on the FOB. Once your passenger opens the door the alarm will go off.
#2 You hit the lock button and your vacuum pump-central locking system is malfunctioning or the air hose in the vacuum pump system is leaking and your locks dont actually lock but the alarm is functioning; awhile later you come back and forget to hit the unlock button and just open the door.
#3 You leave your windows open after getting out, you close the door and hit the lock on the FOB. A stalker that's been following you walks by and reaches in and opens the door.
#4 Car door locked and alarm armed, Superman comes and rips the whole door off of the car will trip the alarm.
Old 09-25-2011, 08:13 PM
I never thought of #4, thanks. LOL
KDW4Him
18
09-01-2021 05:47 PM
Kodebuster
11-05-2020 04:06 PM
maxcichon
05-14-2019 07:30 PM
Hoppy
12-07-2018 07:36 AM
Fildo Dog
07-06-2015 05:20 PM
Quick Reply: alarm, make it work
