How-to: Clean the inside of your headlamp Assembly
Re: How-to: Clean the inside of your headlamp Assembly
First of all: Hello Crossfire drivers.
I'm from Belgium,so sorry for my english!
I've been reading this thread with great interest as i too have this film inside my headlights and this is the first interesting solution i read!
I hope to use this cleaning method as a last resort before reopening my headlights
This film showed up after i did the "paint my inside headlight housing black"!
Before reassembling,i cleaned the inside of the plastic lens with water and a window cleaner.
Only after dark with the lights on and during the day at a certain angle you can see a light film on the inside of the lens.
It is not condensation (used hairdyer,heatgun and sillica gel bags!), so the only thing i can think off is i probably used the "wrong" cleaning method and the window cleaner left this light film/haze on the inside
I have 2 questions and i hope you guys can help:
1) I got some Methanol (99,8%) from the local pharmacy,will this do the job?
2) As i painted the chrome trim black (properly sanded, primed and painted with Motip acrylic spray paint, NO clear coat!), will the Methanol damage the paint as i use 2 or 3 times the rince and dry method as discribed by Maxcichon?
I really hope i don't have to reopen the headlights as i used butyl rubber + automotive sillicon to reseal them!
Thx for helping out!!
on
WAY new reply here (2 years down the pike). Anyhoo. I have a driver's side headlamp with some moldy looking garbage in it. I see below the Methanol cure, and I'm down with giving that a try. That said, I have two questions not addressed here:
1.) If I put methanol in my headlamp, will it in any way affect anything other than the lens? Meaning, the lamp isn't just the lens, it's the whole unit. Should I try desperately not to let the methanol get on anything else? Also, WHERE EXACTLY do I pour it in?
2.) The diagram and photos of the seals included in the linked thread show what appear to be white pvc "elbows" indicated as being a common problem. Why, then, are these "elbows" not a part of the kit shown in the photo. Are they replaced by the smaller button-type seals shown?
Mahalo in advance for your replies!
It's really cute 2c how everyone is tripping over methanol. I am a chemist and we treat methanol like water in the lab. If you want to know what it will damage, just take some rubbing alcohol and dab it on something. Methanol is a drying agent (notice how dry your skin gets when you put alcohol on it. Notice how alcoholic drinks dehydrate the body). It will remove H2O and evaporate quickly. Methanol is, however, strong enough to remove certain nonpolar paints, films, coverings, & adhesives that rubbing alcohol will not remove. It will not destroy the integrity of a material, however (unless u add it everyday so it severely dries the material making it brittle). Just take a q-tip and dab it on a paitned surface within the lens if your curious of its safety. Most of those parts are ABS, PP or similar plastic and I can tell you that in the lab, we use methanol on these surfaces everyday to clean/sanitize them. Just think of it as a really efficient Windex.
If you're afraid MeOH is 2strong, use rubbing alcohol -same thing just more diluted.
As far as toxicity, wear gloves. The most it will do is dry out your skin (removes water) if you don't. Don't worry about MeOH vapors, you do more damage to your liver by drinking alcohol. Just think, which creates the bigger effect: smelling beer or drinking it? The exhaust from your car is more dangerous.
Acetone, on the other hand will destroy the clarity of plastic and many other things. It can remove adhesive, break down plastic, etc. That's the one to watch out for.
on
I called Torco Race Fuels / Phoenix Race Fuels 888-368-6726 about their 100% Methanol and they show purity @ 99.9%
Single Methanol 1 Gallon Bottle - $13.52 plus frt. (my zip = + $9)
Also
though
I'll give it a go & update....
Also
though
Yes, Methyl hydrate is the same as Methanol>> http://en.wikipedia.org/wiki/Methanol but @ 99% you can assume the other 1% is water.
Maxcichon made this pretty clear>>>
“You will need one liter of at least Laboratory grade Methanol. 99.8% or better. I used Electronics grade 99.8%. When this evaporates, it leaves nothing behind. This is very important.”
I used the Torco 99.9%, it did an outstanding job of cleaning with no residual ~ crystal clear…
Found this at Walmart 99.9% Methyl Hydrate | Walmart.ca
As soon as I get my DRL, I will be working on this.
ok - be nice. My car has this interior fogging problem. There's one thing I couldn't tell from the thread. I'm presuming the headlights must be removed to perform this cleaning procedure. Is that right? If so, I suppose the lights will need realignment?
thanks in advance
thanks in advance
If you need the solvent to clean them here is a link to what I used - it worked wonders on my headlights. I would also advise replacing the vents/seals with the retrofit seal kit available from Chrysler. They are pricey but should prevent the interior of the lenses from fogging again.
