Low Fuel Light Flashing
on
Re: Low Fuel Light Flashing
If you try to squeeze more gas in after the pump clicks off the first time it causes the gas to overflow into the evap tube and will make the light flash. I use to try to squeeze more in to top it off and when it got to about a half tank mine use to flash. It's never done it again sense I stopped filling after the pump stops the first time.
Yeah that makes perfect sense, mine is sitting a little under a half of a tank, I guess I was just trying to figure out if it was something bad or not. That is really odd that the system causes the light to flash for that!
My low fuel light start flashing randomly and it turns ON the check engine light . Look like this happen when is little less then half a tank full .
Anyone had this problem ? Any ideas ? Plus it takes me 20 min to fill up the tank same thing makes the gas pump to go off it may be the Pressure Release Valve ... But is been like this for 2 years and i never had any problems so i dent bother .
Last week cost me $ 800 to change the Lock Cylinder Housing and now this .........
PLEASE HELP... Moniq
northwest_crossfire
05-30-2016 05:19 PM
BrenLW
08-05-2015 04:53 AM
axnguyen
07-21-2015 11:41 AM
ja.nko
07-10-2015 03:21 PM
