How to: Replace Clutch in '04 Coupe
Re: How to: Replace Clutch in '04 Coupe
Is this the correct flywheel bolt pattern? I purchased a flywheel from a salvage car, but from the pics it looks wrong. Plus it says LUK, pretty sure the oem flywheel didn't have that.
Thanks Josh, I'll have my mechanic look at it tomorrow since it seems to have a lot of play in it. Hopefully he gives it the okay since the salvage yard looked it over and spruced it for sale.
Bit of a late Thanks but then again I'm just looking now ;-)
Great write up and thanks to whoever created the PDF (just finished printing). Looks like this will work for my 06 as well. About what I expected to have to do once I looked under the car but always nice to have confirmation and a guide to reference before the first time doing some work!
One, though I would hope obvious step, that seems missing was the "Unbolt from block..." step ;-) I think all the tranny bolts are easily seen so that would be 10 to remove if I remember the count (3 on each side from under the car and two on each side from in the engine compartment).
I'll try to remember to write down the sizes if anyone cares to update the info with that.
I know this is an old thread, but would anyone be able to identify the black plastic piece hanging down looks like it's holding onto the bracket the orange piece is connected to in this picture. I recently started experiencing a flicking noise while driving that picks up at about 25mph. Sounds like a rubber band or something spinning around. There was no coinciding issues with the car. I was driving about 80 when it started(6 speed), came out of the blue but nothing changed with transmission, clutch, or engine. It shifts and drives with no difference other than the noise. Pretty soft because there's no heavy vibrations or anything with it either.
Upon trouble shooting I noticed that this piece connected to the aluminum piece above has broken. I'm sure this piece probably isn't my issue, but any help would be appreciated. Thanks.
on
It may be that part. Strange things happed at speed, anything can and does 'vibrate' at different frequencies. If that is all you noticed, go ahead and find that part (maybe in a scrap yard or recycler). Remember, you can also use a MB SLK-320 series from 2004 (ish). You didn't mention which you own but the drivetrain is damn near 100% SLK-320 (N/A) or AMG-32 (SRT-6) series in the 2004 era. Have you figured out how to get that part off, to compare it to something you can pick up? Also, you can delve into the factory service manuals to source that part (free in the downloads section). There are quite a few members here also that can help you source it if it is available. It'll take some homework (unless someone else chimes in with the ID of that piece), and before you take it out make sure you find out if it is an adjustable part (mark the settings like length and points of measurements). You might still have that 'vibration' after it is replaced so be prepared for that as well. Good luck!
×Crossfire1× (09-25-2023)
Yea it's a 6spd 3.2l NA. I'll look through the manuals see what I can find. There's definitely a shortage of parts cars around for me to pick through. Hopefully I figure something out. Thanks for your reply.
hcarter
07-30-2023 02:04 PM
InfernoRedXfire
12-17-2008 05:14 PM
TVT_DESIGN
12-03-2008 09:02 PM
