how to change tire
on
Re: how to change tire
And to prevent this from happening again put a thin coat of anti-seize on the hub where the wheel meets it. You'll be able to tell from the surface rust ring where the wheel touches the hub.
Lol.. I think the thread title should be 'how to remove the wheel' not how to change the tire. As mentioned above, give it a few good kicks around the tire. Don't worry about anti-seize as wheels typically don't get stuck unless they are on there for a long while after getting bolted down by an inconsiderate shop at 200 ft/lbs with an air gun. Good idea to purchase a torque wrench and tighten them evenly, also make sure to tighten all the bolts lightly first and then tighten down in a star pattern to insure good seating.
Kodebuster
11-05-2020 04:06 PM
