Codes 410 and 335
Old 10-17-2012, 09:19 PM
yorktown4's Avatar
Default Codes 410 and 335
Last week I got a check engine light on. I got a code 335. I had the crankshaft position senson replaced.Today while my wife was driving her 2005 the engine cut off. I restarted the engine but it would cut righr off. The check engine came back on. After having the car towed home, I got a code of PO410 and PO335. I could start the engine and feel like I could run the engine up. Can anyone help with this? I'm at tjmjyorktown@aol.com
Old 10-17-2012, 09:31 PM
grip grip's Avatar
Default Re: Codes 410 and 335
Codes are Secondary Air Injection Sensor and Crankshaft Position Sensor. Looks like a crap sensor was installed.
Start reading: https://www.crossfireforum.org/forum...olution-4.html
Old 10-17-2012, 10:17 PM
Mrmiata's Avatar
My thoughts on the crank sensor also.. Advanced Auto has been good so far (7 months) since bosch wasn't readily available at the time.. but it rides behind the seat now for "just in case".
Old 10-17-2012, 11:27 PM
yorktown4's Avatar
I bought the sensor at Advance Auto made by Intermcode. Don't know why I'm getting the code PO410 now.
Old 10-18-2012, 08:47 PM
6000rpm's Avatar
That P0410 is the code I got when the RCM needed a re-solder job; the start of the Mystery No Start problem. Could that be it?
rampntlion
21
02-11-2019 08:18 AM
TOPLESS
02-09-2016 11:28 AM
crossfireusa
10-28-2015 12:03 AM
tritongreen
09-18-2015 07:32 AM
MickeyNasty
09-06-2015 08:29 PM
Quick Reply: Codes 410 and 335
