NAG1/722.6 Auto transmission You Tube videos
BoilerUp started this with his video and I added the others he led me to.
See this explanation of the NAG1/722.6 transmission.
Filter and transmission oil change.
Removing the Valve Body Plate.
Replacing the Electric Conductor Plate.
Re-installing the Valve Body Plate and refilling.
Re: NAG1/722.6 Auto transmission You Tube videos
New Auto Gearbox 1, is the Chrysler designation, it is a Mercedes designed box, 722.6 is the Mercedes number.
See this explanation. and the answer to your question.
on
722.6 ValveBody Sonnax Kit Install
Video showing partial installation of a Sonnax Overlap Control Valve kit. Sonnax part number 68942-05K and cost around $68.00 shipped. This kit helps with Harsh/Bumpy/Flared shifts, and slipping gears. My car had very minimal flaring between 2nd and 3rd, so I figured it may be a good idea to preemptively install this kit to prolong the gear box life. Sonnax only makes two kits for the 722.6(NAG1) that doesn't require special fixturing and bore reaming. Shift overlap control valve sleeve kit is one of them, and TCC Damper valve and sleeve kit was the other one. Since I have no issue with torque converter lockup, that one wasn't needed.
You do not have to drain the fluid to change the connector. It is smart to raise the side of the car with connector on to move as much fluid as possible away from the connector.
Use jack stands.
