How To: Replace the batteries in the alarm module
on
on
Re: How To : Replace the batteries in the alarm module
George, If I remember, doesn't the alarm goes off when you take the positive cable off the battery (simulating a thief cutting the cable from under the car to break into or steal something) first? If you remove the neg first it doesn't alarm, right? If this is so, then how does the alarm 'silence' when folks are removing the fuse numbered '9' and it does not actuate the alarm? I've never tried to 'if this then that' the normal operation of the alarm module. I do know sending 12v down pin 3 if it is triggered by a ground signal, just might cause an expensive end result. Or am I being a little too cautious? Only reason I ask, this might help understand the 'logic' involved when DC is properly connected and then an input (whatever it is) comes through pin 3 of the module in its 'normal' operating conditions. I believe the battery is in the alarm module to power the siren when that 'abnormal' condition is sensed. This is in the siren's circuitry. Is it a simple switching circuit, I don't know. I also don't know what condition 'activates' the internal batteries to sound the alarm, and for how long if 'power' is cut.
The thing to do would be to meter pin 3 with the alarm connected properly and note the state :
1. 12v
2. ground
3. float
Then trigger the alarm with the 'panic' button and see how pin 3 changes ( cover your ears ).
I really think the batteries are to KEEP the alarm on once it's triggered, IE circuitry sees pin 3 in 'triggered' state, and pin 1 no longer at 12v.
I am about to do this.. found this photo for guidance.
http://ww2.justanswer.com/uploads/MB..._170_siren.jpg
OK, just ignore my pdf then
( https://www.crossfireforum.org/forum...arm-module.pdf )
one word of advise - if you see corrosion on the board from battery leakage, don't go any further, get a replacement siren module.
on
on
on
My alarm went off the other day and appeared to burn the circuit board.
I ordered part number 5124443AB from Mopar America but they are holding the order and telling me that I should be ordering part number 4692034AB. I cannot find much info on this part number. It is $134 dollars (4692034AB)instead of the $148 (5124443AB) but I do not want to have them send it if it does not have the same chirping characteristics (3 lock, 2 problem, 1 unlock).
Anyone know what this part number is?
rder Number: 32116852 has shipped. Please note the tracking number and total order cost for your records.
Part Number Part Description Quantity Core Price Price Total
4692034AB Alarm horn 1 $0.00 $148.35 $148.35
Sub Total $148.35
on
Why the 3-pin batts when they make the 4-pin type? Much easier to de-solder and suction off and do a proper replacement!
These Exell (p/n EBC-3/V150H-4P) batteries are rated @ 150mAh compared to the 140mAh Vartas which will provide a slightly longer charge. All other specs are the same.
http://www.mdbattery.com/exell-batte...connector.html
And here’s the Varta equivalent 4-pin 150mAh…
https://cellpacksolutions.co.uk/prod...eable-battery/
