Fog Lamp restoration?
OK, I know the fog lamps are glass and most kits are designed to refresh plastic headlights. I have a bit of road rash on my fog lamps and I would like to see if there is a way to sand them down and polish them clear. Most headlight kits say for plastic only. Is there a way to buff the fog lamps clear? If so, please share with me what to use.
Re: Fog Lamp restoration?
glass can be polished with jewelers rouge, but doubtful you can remove pitting. If you cover them with vinyl like "xpel", they will look better
XPel Headlight Protection - XPel Headlight Protectors - AutoSport Catalog
on
on
on
These things come apart quite easily! Remove the whole assembly and you'll see small tabs holding the lens on. Remove and clean away!
Franc Rauscher
05-09-2016 12:04 PM
