Sticky key help please!
I am in the middle of doing the sticky key fix, and have ruin into an issue I can not find a tip or help for:
I can not get the ignition module inserted back in to the steering column. Has anyone else had this issue?
I have tried scouring the numerous pages/threads/posts on ths subject and apologize if i missed it!
Thanks,
Thanks,
Re: Sticky key help please!
Thanks,
Thanks,
It didn't go in past the lock pin (pin depressed), but I figured it out finally, I had the tumblers in the cylinder, and the column lock pin in the end of the cylinder was protruding, which prevent me frmo getting it all the way back into the column. once I removed the tumblers again I could get it back together.
Thanks for the quick replies!
o55ie18
10-05-2015 05:50 PM
tcar32909
09-19-2015 03:51 PM
