TPMS disable question
Old 06-27-2016, 01:52 PM
Raindem's Avatar
Default TPMS disable question
Hi All. I'm attempting to disable the TPMS on my '05 Limited Coupe using this reference:
https://www.crossfireforum.org/forum...ng-system.html
I've remoed the dome light and accessed the right connector. I assume you have to disconnect the harness before relocating pin #2. I'm having trouble getting the connector apart. I'm pressing and prying at various points but it's unclear where it actually seperate at.
Thanks.
Curt
Old 06-27-2016, 08:24 PM
RED DOG's Avatar
Default Re: TPMS disable question
Did you look at this additional information that's in post #65 in the thread you referenced? This should help you . . .
https://howtune.com/articles/134-dis...sler-crossfire
Old 06-27-2016, 09:03 PM
Raindem's Avatar
No I didn't. I thought it pointed to something I already read. It certainly provides more info on how to get the connector apart and wires out. Unfortunately, I had already broke both of the little flap thingies before reading that.
So, I completed the mod and the TPMS light is out as expected. Good riddens. But now I don't have any dome lights. Nothing else was disconnected while doing this. Where is the dome light fuse? I looked on the interior fuse panel but it wasn'et listed.
Thanks again.
Edit: Nevermind, I found it. It was blown. Must have happened while trying to get the TPMS connector undone.
Old 06-28-2016, 10:30 PM
Originally Posted by Raindem
Edit: Must have happened while trying to get the TPMS connector undone.
That is the reason that we disconnect the battery negative cable before playing around.
stargzr
11-27-2016 05:12 PM
Grind and Click
19
08-15-2016 01:07 PM
topless SRT
06-14-2016 08:13 AM
2004_
06-13-2016 02:31 AM
firedog1
06-02-2016 11:41 AM
Quick Reply: TPMS disable question
