CrossfireForum.org
Loading
- CLICK HERE TO GET RID OF THESE ADS -
Go Back   CrossfireForum.org > Regional Forums > Other Regions > Europe > U.K.
LinkBack Thread Tools
Old 01-04-2012, 11:00 AM
Default Locking wheel nut remover?
Had my xf leak sealed and cleaned stains out today and the garage who done have said they would do a general check of the car....but he can't find the locking wheel nut key and I didn't get one with the car what's are my best options from here?
Cheers
doggboy
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 01-04-2012, 11:02 AM
sk8erjosh09's Avatar
Default Re: Locking wheel nut remover?
Quote:
Cheers
doggboy
I just realized I am in the same boat.... never got one.
2004 Coupe 6 speed///Alabaster/Black 4X000135///
CURRENT Mods: MAF/Air box screen removal.. Elbow baffel removal...MR-MU-MRS Megan Racing Muffler... Plasti-Dip...Real CF interior trim...Bomz Racing Seats...
SOON: BEGi Turbo kit/NW Oil catch can/Wavetrac lsd/Spec Clutch and Flywheel/SRT wing/SRT front Fascia.
Old 01-04-2012, 11:36 AM
PNA's Avatar
PNA PNA is offline
Talk to a reputable tire facility to see what they do in cases like this. You could also check out what might be your best options via a search on the web. Some of the lock manufacturers may have some info. Last option would be to drill / cut them off. Need to be very carful though to protect the wheel and the bolts, or you might have to end up replacing the bolts............
Good Luck
EDIT: There are some youtube videos on this that make it seem pretty easy to get these off. One Example: http://www.youtube.com/watch?v=T8Uc2SlkSPM
Others provide more detail on tools etc. Seems like the locks only make it hard for the dum theives to prevent theft of the wheels..................
PNA
2004 Sapphire Silver Blue Metallic
Crossfire Limited #2715
Autostick with Gray/Dark Slate Blue Interior
K&N Highflow Filters
Old 01-04-2012, 11:52 AM
alaxfire's Avatar
Courtesy of BLACKSRT-6 :
Quote:
Ever see one of those cheap as sh!t sockets with all the spring loaded pins inside that is supposed to fit any size nut. That's what I used when my lug key went missing and it worked perfectly. I now have two of those crappy pin loaded sockets!
2005 Inferno Red Roadster LTD # 59708
( done a bunch of stuff to it to make it prettier and faster,
but who really cares ? )
Old 01-04-2012, 11:58 AM
Quote:
That is the best idea I have ever heard!!!
Old 01-04-2012, 12:09 PM
Off to get me a spring loaded socket thing then now lol, If that doesn't work I have been given the ebay link of someone who can reproduce your key from a picture off your phone for around £30 I'll post link up later when I get home
Old 01-04-2012, 03:43 PM
You can use a socket which is a shade smaller than the locking wheel nut. This must be a tight fit. Hammer this on and remove the locking nut. Now you need to get the locking wheel nut out of the socket by drifting it out with a drift. Or you can buy some locking wheel nut removing sockets which screw on the opposite way to the locking nut. I have a set if you want to borrow them. Hey,that would be a nice run out for the Crossfire to.
BTW. You will need a new set of locking nuts to fit afterwards
Jon
3.2 Crossfire Auto
2004
White
Sprint Booster
Old 01-04-2012, 04:03 PM
Mr Kilmouski's Avatar
Hi
Had the same problem, just went to the local MB dealer they had a set of replacement keys, worked the way thru the case wich covered the 170SLK and within 5 minutes found the one that fitted. £28 and never had to damage a thing.
I suggest this method as it worked perfectly for me.
Old 01-04-2012, 04:28 PM
Quote:
Originally Posted by Mr Kilmouski
Hi
I suggest this metod as it worked perfectly for me.
Got a Merc dealer not to far from me, will call them tomorrow....what shall I ask for?, locking nut key for slk 170?
Old 01-04-2012, 04:31 PM
Jon
Appreciate the offer buddy but after Christmas I've got to tighten the purse strings...and that means no more petrol wasting (wife's words not mine )
By the way is your white xf for sale?....seen one on ebay for sale and there can't be many white ones about?
Old 01-04-2012, 04:35 PM
Question Re: Locking wheel nut remover?
Anyone know what size the wheel nut is on crossfires?
Old 01-04-2012, 08:39 PM
SparkieSRT6's Avatar
I'd search in the back hatch, in and around where the jack, tire sealant, spare tire kit without the spare tire is lol. That's where I would have kept it. Good luck.
S.O.C.O. Member
SPEEDRIVEN TCM TUNE
HIGH OUTPUT LED DAYTIME RUNNING LIGHTS
AMG STEERING WHEEL PADDLE SHIFT KIT (LATEMODEL21)
IDEAL FRONT BRAKE PADS/NEEDSWINGS CATCHCAN
HANKOOK VENTUS V12 K110'S/EUROCHARGED TUNE
RESONATOR DELETE
(.v.)
Old 01-04-2012, 08:54 PM
Mrmiata's Avatar
Gator Grip Universal Socket Kit
Everything you need in the palm of your hand
Maybe you've seen the "Gator Grip" on TV and you wondered if it really did all they claimed. I can tell you it does! This one socket fits all nuts and bolts from 1/4" to 3/4" and all metric sizes from 9mm to 17mm. And it fits odd shapes like wing nuts and eye bolts too. The trick of the Gator Grip is that the socket is made up of 52 spring loaded steel roller pins that automatically conform to the shape of the nut, bolt or whatever you want to tighten. And here's the best part: I've combined it with a flexible stubby ratchet and a belt pouch so that you have an entire lightweight socket set that fits in the palm of your hand and you can carry it on your belt. It also comes with an adapter that lets you to use the socket with your electric screwdriver. When I show the Gator Grip in person--everybody wants one. This is the coolest new tool I've seen in a long time.
#69505 Gator Grip Kit $59.95Quantity:
No self respecting wheel thief leaves home without one!.. Also available at most local pawn shops for a song-dance and $3.50 (at least mine was)
'04 ALABASTER WHITE #11540
The Miata was Exciting - The Crossfire is THRILLING!
Begi Turbo Kit - $5 Front Lip - $4 Mirror Mount
6000k HID Low's-Clarion CZ501-Fusion 250 watt Bass Canon
I Love "Nay Sayers!"
Old 01-04-2012, 10:22 PM
metrocop's Avatar
I believe the last Audi A6 I had, had the keyed socket on a spring on the handle of the lug wrench....Perhaps MB did the same.
Old 01-05-2012, 12:51 AM
Was that one for sale in the UK?
White wasn't available for the UK market, so I resprayed mine last year. It use to be blue. You can see it being done on UK Crossfires - For owners of the Chrysler Crossfire in the UK under (photo gallery Bodymans respray).
Don't want to sale her, but you never know.
Jon
3.2 Crossfire Auto
2004
White
Sprint Booster
Old 01-05-2012, 03:21 PM
I JUst phoned them and explained the problem, that I had a crossfire and that the key looked the same as the one I had on my Previous SLK 320. They have should have 2 sets of master keys. You want to try the older set which has the star shaped keys in it.
The part number should be something like B66 40 82**
** being the key number which fits your lock.
Any probs give Paul a call at Mercedes Milton Keynes. He is a Star and saved me a fortune
Old 01-05-2012, 04:50 PM
Jon
Here's the link to the one on ebay I quickly looked at:
2004 CHRYSLER CROSSFIRE WHITE | eBay
Old 01-06-2012, 03:50 AM
Looks like they only painted the outer panels and left the door shuts and engine bay in black. That's the hard bit of a colour change.
3.2 Crossfire Auto
2004
White
Sprint Booster
Old 01-12-2012, 04:04 PM
Thumbs up Re: Locking wheel nut remover?
Update: Got a locking wheel nut today........walked in local MB dealership in work clothes, they looked horrified as If I was there to hold them up Said could I try your locking wheel nut keys on my XF as I have lost mine, they seemed puzzled and said this is Merc only we don't cover chrysler here....I then went into explain the birth of the xf mode (seem to do this quite a lot lol?) to which they still looked puzzled but got the parts guy to come have a go with his set...and badda bing sixth nut in we had a fit....£27 and a few hours for new one to be delivered and I now have the holy grail of my my missing wheel nut, refurbed ally's here I come
Old 01-13-2012, 04:02 AM
What did I tell ya. Sometimes you just need to explain things clearly to the guys behind the counter and eventually they will understand.
Now you have a key think about how much grief you have been saved from, and no further damage to your precious alloys.
Advertisement
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Contact Us - CrossfireForum.org - Archive - Top
Search Engine Friendly URLs by vBSEO 3.5.2
