SRT6 Suspension??
Re: SRT6 Suspension??
I switched my SRT to stock springs & shocks because I wanted a softer ride. It is plug and play exchange. Should lower the suspension slightly based on my experience. Am willing to sell my SRT springs and shocks with only 3,000 miles on them for about 50% of cost of new base model set. Price $350.
on
Originally Posted by MMZ_TimeLord
spensley,
Yes, HDDP did in fact put SRT6/AMG sway bars on his '04 (race prepped). He also did an SRT6 brake upgrade. Not sure about the springs and such (not off the top of my head anyways).
Cheers!
Cheers!
PS: How ya been Jody ? I have some interesting updates, but still working on them...
Originally Posted by tjames.bell@gmail.com
Is the SRT6 suspension different from the limited suspension? If I put the SRT6 suspension on my limited would it be any stiffer and would it lower the car at all? Thanks for any help you can give!!
Install the front SRT6 sway bar...
Install these coilovers...
Or, if you want to stick with the separate spring / damper OEM set-up.
Install these springs http://tunertools.com/proddetail.asp...2D5080&cat=116 and replace the perch pads with #1's
Install these dampers http://www.koni-na.com/konisport.html
What do you think about the ride of your SRT6 after changing out your springs and shocks? Big improvement? Worth the money? Would you do it again?
Originally Posted by Shawnkey
Did you notice a considerable difference in body roll with the sway bar?
rogerlemoine
10-26-2015 12:02 AM
