What's under the foam/packaging holding the tire tools?
I did a search on this and didn't find anything.
Has anyone removed the foam or like (for a lack of the right terminology) that holds the compressor, tire tools, and first aid kit in the trunk? If so, would there be room to store a spare donut?
Re: What's under the foam/packaging holding the tire tools?
I removed the foam padding and inserted a JBL custom built audio system. There's plenty of room for alterations. However, I replaced some of the foam as a damper/insulation for the system. The foam does serve as an additional crumple zone unit but if you "allow" for the re-insertion of foam on the corners it may still serve as an assistance regarding the crumple zone.
I have removed all the foam filler and lined it with dynomat. I bought a piece of 4x4 half inch plywood and made a custom enclosed box. I put in two 10 inch punch stage 1's on each side (fit perfectly) and mounted an amp in the middle, then carpeted it. Its sweet. I was also able to stuff the small tire air compressor up behind the rear bumper on the drivers side...there's just enough room. There are a few pics in my gallery of the process. I also raised up the OEM floor piece that was there by cutting a 2x4 in 2 inch pieces and mounted them vertically in the corners with velcro on top of them. The old floor now rests, or hovers, 2 inches above the subwoofers to make the whole set-up invisible. Nobody knows they are even there and they sound nice.
I'm not worried that the foam is not there anymore...when my times up, its up. At least I was having fun in my Crossfire. You only are on this planet once! Just my 2 cents.
Kodebuster
11-05-2020 04:06 PM
81's
09-13-2015 04:34 PM
