Brake Pad Sensors came on...
Re: Brake Pad Sensors came on....
Originally Posted by Dodgerpro
I want to order my brake pads from buybrakes.com is it okay to continue driving with the light going on when pressing down on the brakes.
Or when the light comes on, do i have to change the pads RIGHT AWAY?
on
I just ordered a set of front Rotex Gold from: http://www.brakeworld.com. Around $139 for the SRT6 set (coupe is around $85).
on
When I said "set", I meant for the fronts. The rear Rotex Golds for the SRT6 are another $68 / $60 for non SRT6. Of course there's S&H too.
The reason I'm going with them is that I am so sick of dealing with brake dust for the last 10 years with my '95 Chrysler LHS, and now the Crossfire. Supposedly the Rotex don't give off the dust.
Sorry to interrupt... Since you're interested in brake pads that are better than the OEM, I recommend: http://www.porterfield-brakes.com/. I use the race compound, but they also make them for street use.
R4-S High Performance Street and Autocross
For high performance and heavy-duty street conditions. Perfect for prolonged everyday street use while also being capable of tolerating the most severe street use without any fade. Rotor friendly of course. The R4-S friction level will give you an impressive increase in stopping ability with very minimum pedal effort. R4-S compound has the absolute lowest noise and dust levels, far below OEM equipment or any other high performance brake material. Good for autocrossing, some drivers' schools, and rallies. The R4-S compound is available for virtually any vehicle sold in the US. We also offer the R4-S in pad sizes for competition type calipers that are used under street driven conditions.
Here is a list of all pads, including part numbers and prices: http://www.porterfield-brakes.com/cg...field/pads.cgi
Since i need to brake pads, does that mean i need new rotors? I'm still driving the car, and the rotex gold pads i ordered should be coming in by next week. I should be OK driving the car until i get the pads right? I bought the pads from: www.BUYBRAKES.com
Thanks Guys
Thanks Guys
Thanks Guys
Thanks Guys
My car only has 25k miles, isn't it kinda early for new brake pads?
Does the fact that i drive me car like i stole it, every single day, have any factor.
Driving it like you stole it - can definitely be a factor.
I just finished changing out the pads and rotors on my xfire and the brake pad wear indicator is staying illuminated. I noticed when i took the old sensor out of the old pads, they had markings, but being the replacement pads didn't have any replacement sensor attachments in the box. I moved the old snap-on sensors to the new pads thinking it shouldn't be an issue if they are designed to take a little wear. I am wondering if there is a procedure to reset the computer or do I actually need to replace the sensor all together?
Thanks!
Thanks!
Thanks!
Thanks!
Order your brake pads from www.brakeworld.com and get the Rotex Gold Kevlar pads. I just put them on my car and they are excellent. High performance , and virtually NO BRAKE DUST on your wheels. I would not use any other pad !!! Many others here in the forum have installed them and this is where I got the info on this product.
