Suspension Help Needed... Perch Pads!?
I'm trying to find perch pads for the front and rear springs of the Crossfire and I have been unable to find a clear definition/description of what exactly it is I need. I want to get pads that are thinker than the stock pads because the suspension setup I’ll be using rubs a little in the front and I want absolutely no rubbing what so ever.
So what’s the difference in the numbers of pad thickness?
Where can I buy good quality perch pads?
Re: Suspension Help Needed... Perch Pads!?
If you have installed it already, where is it rubbing ? What size wheels / tires ?
More information will get more information...
Originally Posted by HDDP
I'm confused as usual... You say that "the suspension set-up I'll be using rubs a little in the front"... How do you know that the suspension set-up you'll be using rubs in the front ? have you installed it
He is using the OEM wheels and OEM sized tires… I will also be using the OEM wheel and tire set up.
I believe…
Springs: Eibach
Shocks: Koni
I will be purchasing Andrews’s suspension from him when he goes to turn in is Crossfire. And he has showed me that upon turning sharp while in reverse the front tires rub just above where the access panel is for the fog lights.
I believe…
Springs: Eibach
Shocks: Koni
I believe…
Springs: Eibach
Shocks: Koni
Anyway, the Perch Pads work like this... There are DOTS molded on the side of the pad...
3 dots "..." = thick
2 dots ".." = medium
1 dot "." = thin
The OEM ships with "..." on the front and "." on the rear... The difference in thickness is only about 5mm from thickest to thinnest...
Hope this helps...
That rubbing is normal... If noticed from photos there are "rub spots" designed into the wheel well... The rubbing in reverse happened on the OEM that is why they built the rub pads into the wheel well...
1 dot "." = thin
Hope this helps...
1 dot "." = thin
Hope this helps...
But nevertheless thanks!
Oh, and do you know (for future reference) where I could by perch pads for the Crossfire/SLK?
chturner
19
10-14-2019 04:42 PM
2005 Ragtop
10-03-2015 03:01 PM
ritous1
09-26-2015 01:27 PM
Valk
09-17-2015 11:43 AM
