Run Flat tires
on
Re: Run Flat tires
Originally Posted by gdobbins@twcny.rr.com
Now that the Crossfire has been available for several years and being as though there is no spare tire are there any runflat tires that could be used on the Crossfire?
on
Re: Run Flat tires
the biggest difference your going to notice with the runflat tire is the STIFFNESS because the sidewall of the tire is so much thicker tougher it has less flex or cushion when hitting bumps or holes or whatever. i'm sure they do have them available in our sizes... check: TIRES.COM
the only real benefit of these tires is the chance you pick up a nail or something your less likely to have a blowout. but you have to be careful because of the thick sidewall you won't be able to tell when you have picked up a nail or screw it won't droop down like a normal tire. you'll have to get routine air checks once a month or so!
on
Re: Run Flat tires
From the research that I have done the biggest tire size is 18", I have been unable to find any 19" run flats. They do make inserts that can convert tires into run flat tires.
http://www.bulldogdirect.com/TP-wheels.asp
Re: Run Flat tires
The BMW X4 has the same front wheels as the xfire so I checked with their tyre suppliers as to what I could do to change to run flats. The pretty comprehensive reply is attached, I guess that it is equally applicable in the US.
Dear Mr Lawton
Thank you for your recent e-mail.
We would advise that we are not aware of your Chrysler Crossfire being fitted as OE (Original Equipment) with run flat tyres. We would also recommend that Run Flat tyres require specific Run Flat wheels (Run Flats not to be fitted to standard wheels), as well as a pressure monitoring system for each wheel, with a Dashboard mounted warning display. Therefore, please contact your vehicle main dealer to seek their help and guidance, to determine whether you have or have not got this particular set up on your Chrysler Crossfire.
We certainly have no record of a Run Flat tyre system available for the Chrysler Crossfire.
We have allocated your message the reference number indicated above. If you need to contact us again regarding your message, we would be grateful if you could include the reference number.
Once again thank you for your interest in Michelin.
Yours sincerely
Michelin Tyre Public Limited Company
THIS WAS MAEKED FOR MY USE ONLY, so use in the forum only, please. I am not aware of any OEM run flat set up and so it sounds expensive.
Have a great week end.
Michael
Dear Mr Lawton
Yours sincerely
Michael
Kodebuster
11-05-2020 04:06 PM
axnguyen
07-21-2015 11:41 AM
shawnwatson9493
07-09-2015 11:47 PM
