60-0 braking times
on
Re: 60-0 braking times
here you go:
http://www.caranddriver.com/roadtest...crossfire.html
http://www.caranddriver.com/roadtest...ire-srt-6.html
Maxwell, check out my old comparison thread, it has statistics from the magazines, old and new.
https://www.crossfireforum.org/forum...ead.php?t=9100
this must be the SRT6 braking specs and not the Limited right?
Snob and Driver have the SRT6 at 70-0 mph @ impending lockup: 157 ft Can another 10mph actually have this big of an effect on stopping?
Originally Posted by Maxwell
is this correct Braking 60-0 m.p.h._______AMX___115'________Crossfire__________ 114'________
so basically there is no real reason to upgrade the stock Crossfire brakes, since it stops as good as a Porche 911 GT3, so the only reason for the extra swep area on the AMG and SRT6 is to allow the brake rotor to disipate heat, so there is no benifit for the street or fast highway speeds. good to know.
I thought going larger would give me shorter stopping distance, I guess not?
srt6 70-0 mph @ impending lockup: 157 ft
Limited crossfire 70–0 mph @ impending lockup: 161 ft
I'm just gonna assume the distance variation is due to the drivers foot not applying the same pressure at the same instance the measurement was calculated could be using different tires also.
Your tires are much more a limiting factor than the brakes themselves. The difference in braking distance between a top performance summer tire and a crappy all-season tire is likely more than the difference between stock brakes and bigger brakes.
Roty135
17
10-11-2018 10:11 AM
PNA
07-27-2015 12:28 PM
