Rear SRT pad replacement
I replaced the fronts with Rotex golds but could not figure out the rears with the pins. I then read a thread about the pins being spring loaded and if so, could some one explain to me how it works and how I can replace them? It just didn't hit me as simple when I had it all apart. It's funny how the exsiting pads look new but have a low but noticeable "grind" sound when braking and especially braking during backups.
Thanks in advance,
Thanks in advance,
on
Re: Rear SRT pad replacement
Do they scrape all the time when you brake or after the its been sitting for awhile? The rotors get a rusty film on them(which is normal) after sitting for sometime more so after washing your car or in damp rainy weather. Mine does the same for short distance then goes away. If the rotors and pads look good then that's most likely the cause which is normal but sometimes annoying. Did you download the service manual it will tell you how to change the pads. https://www.crossfireforum.org/forum...ad.php?t=13875
on
Originally Posted by Punkin
Robby, they scrape all the time while braking. I'm not sure why because there is alot of pad left. I don't know why I didn't look in the manual. I'm sure I have downloaded it.
victorlautreamont
06-29-2017 01:22 AM
frankthetank81
12-06-2015 06:25 PM
