Anti Squeal Lube Question
I could not find what I needed by searching so I'll try a new thread. In Andrews excellent brake pad replacement instructions, he doesn't mention using anti squeal lube on the front pads unless I missed it. It is mentioned on the back pads. I have replaced pads before on other cars but never had to use the lubricant. I'll use it on the rears as per the instructions.
Do I need it on the fronts ?
Any brand preference ?
Any parts store ?
How does it work ?
I have the Rotex pads and a 7mm allen socket on order and will tackle the job soon. Any info on the lube will be appreciated.
Any parts store ?
How does it work ?
Re: Anti Squeal Lube Question
I would recommend using it on the front as well. You can pick it up at any auto parts store and brand is not that important (I wouldn't think). Just for info, I had some but didn't use it on front or rear, and mine has not squealed the first time. But, I had very few miles on the car when I switched to Rotex Gold pads and there was still a sufficient amount left from the factory pads.
on
1 Post
Originally Posted by chuck65
Did you turn the rotors ?
Originally Posted by dakota-boy1
Had rotex brake pads put on 2 weeks ago, lube the back of each pad over night with anti-squeal lube. Everytime I back up, hitting the brakes I get a loud squeal. Not sure if it will get better, but sure a pain in the ***.
Is the loud squeal in reverse gone yet ? How about going forward ? I'm Getting closer to putting on my Rotex pads. Any tips ?
Good luck.
Don
Once in a while I get the squeal. Seems to be getting better. You need to turn the rotors, I didn't and regret it. I had only 16,000 miles on my vehicle. Didn't think I needed to turn the rotors but I should have. Never to old to learn!!! Sure don't miss all the dust on my wheels.
Good luck
Don
Good luck
Don
Can anyone provide the procedure to remove the rotors? I think it's easy and only requires the removal of one bolt.
You know Dakota Boy it's not too late to turn your rotors. I believe they can redress your new pads also.
Thanks
Originally Posted by FP
Another title for the wondering mind? I'm holding back, but it's not easy. Apkano?
Easy to fix...pull over and kick the bi**h out to the curb...you have plenty of girlfriends if we are to believe your gallery!
Or are you talking about bedding new pads...personally I like to wait for another time of the month.
I had my Rotex Gold pads put on today. I was going to put them on myself, but decided it was not a good idea to not turn the rotors. The grooving wasn't the issue but the glazing and coating that the original pads left were. The mechanic only took off .005" because there was only 6000 miles on them.
I used a product from Permatex called Quiet Brake Pad that I sprayed onto the entire back of the pad the night before installation. When it dries, it forms a rubber like coating.
danimal suggested "bedding", attn: FP, the pads which I did. 2 firm stops from 35, two from 50, and 2 from 60. Look up "bedding" to see why this is recommended.
So far no squeak or noise of any kind. Of course the dust issue still needs some time to tell. As far as I can see by reading the threads on the dusting and squeal problem, most that complain didn't turn the rotors or use a anti squeal product. I can't stress enough the need to do both.
There's a thread on the SRT6 site about Rotex and some are dissapointed with the results. Some complained of dusting under hard use. I found an interesting review on Rotex. http://www.thetruthaboutcars.com/rot...e-pads-review/
After about a month I will let you know if I'm having any problems with the installation.
Thanks to all for your help and input.
jimf
10-10-2015 10:22 AM
2005 Ragtop
10-03-2015 03:01 PM
