Rim won't come off!!!
Old 06-20-2008, 01:55 AM
Black SRT's Avatar
Default Rim won't come off!!!
Ok I was going to check my brake pads before I go to the track this weekend but my rim seems to have seized to the hub. I've pulled, kicked, and beat on the damn thing but no luck. Anyone know any tricks to get the damn thing off. Oh and the sencor in the brake pad, is that thing going to tell me if the pads need replaced?
Old 06-20-2008, 03:48 AM
arado's Avatar
Default Re: Rim won't come off!!!
I had the same thing happen on my Mini Cooper. It took an eight pound sledge hammer to dislodge. Manufacturer failed to put anti seize on hubs. When I acquired my Crossfire I removed the wheels and applied antiseize. I refresh whenever removing wheels....
Old 06-20-2008, 04:40 AM
+fireamx's Avatar
Yeah, I was going to suggest the sledge hammer too, but you may just want to put a 4"X4" piece of wood in front of the rim (on the back side) as a buffer zone before you hit it. Also, put a big piece of cardboard down on the ground so when the wheel falls off and tips over, you won't scratch the lip of the rim when it hits the ground.
I have to do this all the time with my 1 ton Chevy Van even though I smear "Never Seize" on it everytime I take the wheel off.
Old 06-20-2008, 04:04 PM
MI1XFIRE's Avatar
This is very common here in Michigan
The easiest way to get the wheel off is in fact very simple:
Loosen the lugnuts but don't remove them completely
Put it in drive and go a few feet and hit the brakes
For good measure, do the same thing in reverse.
Don't forget the antiseize around the center hole of the wheel when you put it back together. This is where it corrodes to the hub.
Old 06-22-2008, 07:37 PM
BLKFIN's Avatar
ADDICTED TO BOOST
Kicking the Sh*T out of the wheel has always worked for me.
Old 06-22-2008, 07:41 PM
blacklimitedcoupe's Avatar
I agree...remove the lug nuts, sit on the ground with your feet facing the wheel and kick the bottom of the rim...it will pop loose.
Old 06-22-2008, 09:10 PM
rodimus's Avatar
When I was 16 I took a rim off by slamming into a curb. I would not recommend that in this situation though.
Old 06-22-2008, 09:51 PM
Voyager's Avatar
yeeaaaah dont listen to rodimus.
Old 06-23-2008, 03:41 AM
Black SRT's Avatar
Thanks for the replies, I guess I just need to beat harder,
TerryR
12-13-2019 03:27 PM
Jonacross
20
07-17-2017 11:19 PM
Ed Mahoney
09-20-2015 10:35 PM
Power Sedan
09-20-2015 09:24 PM
caseydeankopp
09-13-2015 07:25 PM
Quick Reply: Rim won't come off!!!
