Spring pad question
Spring pad question
A couple months ago I installed an Eibach Pro Kit in my car. I was smart enough to mark down the part # to the rear spring pads but forgot to do so when replacing the front springs (in a rush) I seem to remember someone on this forum mentioning that the spring pads on our cars have a marking other then the part # to ID the thickness of the pad. I found the part #'s several times on a search but could'nt find anything else. Are there any markings that identify the thickness of the pad without removing the front springs?
<--- Huge Horsepower
on
Re: Spring pad question
https://www.crossfireforum.org/forum...ad.php?t=26341
I used the search function and entered "spring pad" (the title of your thread) and look what popped up!
https://www.crossfireforum.org/forum...ght=spring+pad
Check out post #7
Check out post #7
Hi BrianBrave,
Thanks for the response. I have the part #s but I think the part # is only visable with the spring removed, is that right? Someone once posted there is a mark of some type to identify which pad is in the car without taking the suspension apart. They said you only needed to pull the wheel and stick your head up in there to see the marking. Maybe its wishfull thinking but I would prefer to know whats in there without taking the car apart. I would hate to disassemble the front to find out that my spring pads are 5mm (the thinest)and then have to put it back together and get it re-aligned
on
Originally Posted by Isellthem
Hi BrianBrave,
For example - a front pad with one dot = 5mm (...01 84) two dots = 9mm (... 02 84) etc.. this way you can tell which one is installed in your ride by just touch (if you can't see it)
Front:
A 210 321 01 84 (5mm)
A 210 321 02 84 (9mm)
A 210 321 03 84 (13mm)
A 210 321 04 84 (17mm)
A 210 321 05 84 (21mm)
Rear:
A 210 325 01 84 (5mm)
A 210 325 02 84 (9mm)
A 210 325 03 84 (13mm)
A 210 325 04 84 (17mm)
The pad below has only one dot.
I purchased a set of four at my MB dealer for like less then $25
on
Originally Posted by Mad_Med05X
OK
So The lower the pad number / thickness = a lower stance for your car?
Does the pad soften the ride?
Yes - lower number = lower stance - but only marginally
assuming you replaced the 21mm pads in the front with 5mm pads - you would only drop a little more then 1/2 inch. Great for fine tuning.
No - Not that I could ever tell
Originally Posted by FrSailorman
Hi Guys,
I'm also thinking about replacing the Spring pads on my limited.
Just a technical question : are they easy to replace ? How do you proceed ?
Thanks for your help on that topic.
Cheers
Cheers
How hard is it to replace the pads while installing lowering springs?
on
What is the stock size of the 05 Crossfire pads Front & Rear?
Easy to replace when you remove the springs.
If your lowering your Crossfire - dont forget to shave the bump pad (A) in the shocks.
Hi Guys,
I'm interested in replacing those pads. Then, I removed one rear wheel this morning to try to find the part number and I didn't find anything like that.
So I've decide to take some pictures and share with you just to know if I was looking where needed.
Firts I need to be sure that removing the wheel is enough to have access to that Spring Pad part number.
If yes, from the pictues, would you tell me where I should look.
Thanks so much for your help.
on
on
OK, I' ve found where it is on the picture : left upper side of the spring !!! Am I right ??
Depends on the factory set up - I had the thickest pads in the back (17mm) and the second thinest in the front (9mm) but the pads are cheap - about $30 for a set of four
Does this really have to be done?
Can you better explain what need to be done? And why?
SHAVE WHAT? How much?
on
