Adjustable Rear Camber Arms
Has anyone here used any of the following on their Crossfire?:
MB-Arts Adjustable Camber Arms, MB-170-ARCA
Top Speed Pro-1 Performance TRMBENZ-RTCA
(They list these as fitting numerous MB chassis in addition to the R170)
Megan Racing lists a part for the W203 and W208 ,MRS-MB-310, that can be had for under $200.00...
(Would be a good buy if I knew they would fit)
I am getting ready to do brakes, Tires are a few weeks old, would like to get the alignment issues taken care of while I have the wheels off, so any input is appreciated.
Thanks,
Thanks,
on
Re: Adjustable Rear Camber Arms
Yeah, I saw your post about the Megan's that what got me thinking and searching. I'm really not thrilled with the idea of making my own if something suitable is available reasonably priced. THe MB Arts are $310, and the Top Speeds about $240. I was just hoping that I wouldn't have to take a $200.00 chance on ordering up a pair...
on
Thornh: let me know, please the info you find out about the rear camber kits...I really need them... the larger/wider tires recently installed have effected a slight negative camber...Thanks Carl
Carl- I'll let you know what I end up doing with the rear camber. I really want to maximize my tire wear since I just put a new set on. I have the eccentric bolts for the front ready to install as needed to get the front in spec. Hopefully that will give me enough adjustment. I may just have to take a chance on the Megan Racing bars and see if they fit. So far Megan Racing hasn't responded to my email requesting additional info.
Thanks,
Thanks,
Thanks
on
Here's the ones Beaner was referring to... save yourself $200 as these work just as good if not better then the name brands!
https://www.crossfireforum.org/forum...r-cambers.html
on
Just gave both Crossies new 4-wheel Laser alignments and the Mechanic was thoroughly impressed with the setup.
A little more info I have gathered:
Mb-Arts - solid aluminum construction - $310.00 plus shipping.
TopSpeed Auto hollow steel construction (spoke with them today) $238.00 shipped on ebay
Megan Racing - No response from my email to them over a week ago, site lists as steel construction for C-class sedan 01-07.
(A little digging into the MB part number {210-350-34-06} reveals that this part fits almost all C-Class vehicles mid 80's to mis 2000's and some E and SL as well. Not sure if the are hollow or solid - I'm not keen on hollow for a load bearing application, but I may be willing try a set of the M-R bars for less than 200.00 as as opposed to DIY.
I'll keep this thread updated once I decide which way I go and get something installed.
Like I said, I don't know if he'd make any, I just know he does really nice work.
finally received the Megan Racing adjustable arms this week. went to install them this morning, and found out that I don't have the triple square 12 pt bit to remove the outer bolts... after searching could not find locally, now I'm waiting for the tool to arrive from amazon....
Sorry for the late followup, but I finally got the camber arms installed yesterday. Haven't had it aligned yet, but the install was very easy, they fit nicely. Will report back again once I have it aligned.
ZX2 Nick - I left them pink - cant really see them unless the wheel is off the car so the color doesn't bother me.
