19x10 or 19x10.5 wheels
on
Re: 19x10 or 19x10.5 wheels
I have been spending weeks trying to find wheels with no luck. So know I asking you guys and gals for help please please please.
18x8.5 front
19x10.5 or 19x10 rear
Silver preferable
With lips or dished NOT flat faced.
And less than $1,000 per wheel.
Any suggestions please.
18x8.5 front
Silver preferable
speedy. I got 4 Lexani gloss black machined faced 7 spoke 19"...8.5 front and 19"...9.5 rear for around 2,000 3 years ago... really like them...They have a huge selection...Carl
Haha.
Wanted 10 - 11 for rear which didn't leave much options in a 5x112.
Or to heavy or $$$
Thought about there hyper black, more like a light graphite.
Tire rack is fast.
Less than 22 hours after they shipped my new tires arrived
Coded tires.
The Yokohama ' s made the 5th week 2017, in the Salem Virginia plant.
Why I went with yoko on front, made in USA.
The continentals 4th week 2014, 2 years and 2 months old, fine with me at that discount. Made in there Slovakia plant.
I haven't found a good made in usa 285 all season tire for rear. Was going to get the bfg but without the closeout price, I couldn't pass these up.
Coded tires.
on
Tire rack is fast.
Coded tires.
Coded tires.
On those continentals, are they branded continental or the barum bravarus (European continental) branded?
Looks like they where drilled a 114.3 then chamfered out to a 112.
But they are cone not conical
Can I find lug bolts in town with the mb size and thread in a con instead of a conical?
Or send them back
Or send them back
Going to put them on tomorrow with lug bolts, and probably order studs.
I weighed them earlier.
They are wider and lighter than stock wheels.
They are looking good against the ssb, when I order the studs and lug nuts I need to find some silver instead of chrome, the chrome lugs stick out.
Rear, had to cut 3 threads off the bolts I got for the back so they wouldn't catch on the parking brake.
Front, took 1/8" off the depth of the dust cap for the hub for them to mount, can't use the center cap on the front
Next weekend might take off the dust caps off of the hub and clean and paint.
Does anyone know if the have seen dust caps that are more squared off instead of rounded?
Or any dust caps for front hubs that look any different?
If there was a dust cap that can be presses on the inside of the hub instead of the outside, then I can use the center caps.
Wheels and tires are looking good. How much clearance do you have between the 285/35/19 tires sidewall and the cars inside fender well? So your in Illinois. Rudy (Accelerated Industries) is also in Illinois with my car. He's bare block building a SL55 carrillo weistec engine with a modded V-12 cylinder transmission to drop in my SRT-6. I'll be picking it up late spring and would like to stop by to look your wheels over. Squirrel Crusher
Only problem is I live in southern il and he is in Chicago about 5.5 hours away.
If you want me to text or email some detailed pics I can?
These only have a 2mm difference in back spacing on front and rear, the wheels just are 3/4 wider sitting outward and inward, the tread of the tire is only 2mm difference than where it was positioned on previous wheels.
Damn it, I would sooo love to see it.
Got to Louisville, when I left I had a slight vibration, but after 40 miles it started to smooth out, nice and smooth now.
And I don't have the hub rings on yet, they forgot to mail them with the new wheels, be putting them on next weekend if they get here in time.
Might go ahead and order studs and nutts also as per reccomentations of the wheels shop for Crossfires.
