19x10 or 19x10.5 wheels
I am getting a small rub on front, think it is from a screw top center, will look this weekend.
Might get a fender roller and push out a scosh.
Didn't think there would be any problems with the offset I got.
Here is the front, and the bolt that is hitting.
Here is the back, drove front tire onto a rock pile to flex, and push tires into wells.
3" clearance under back tire and ground
on
Re: 19x10 or 19x10.5 wheels
CLEARANCE SALE
michelin pilot sport a/s plus 285/35r19 for only $184
on ebay best wheels online.
Treadway 500, all season tire.
FOR WIDER THAN STOCK WHEELS ONLY........
these are runflat tires so a very stiff sidewall and will have problems sealing on widths not reccomended.
I bought 4, have 2 spares for this price.
and MADE IN USA...
and MADE IN USA...
The wheels look nice! What offset are they? I know you said within 2mm of stock, but just looking for more information. Wondering if I can fit a 19*11 in the rear and what offset to get (custom).
Rear 19x10.5 +22
I really liked the hyber black, if I could have seen it in person I might have got that, it is like a black chrome.
Stock if I remember right is +32 on front and +25 on rear.
They wheels stick in and out wider but the tread is only 2mm different on the front and 3mm on back, wheels are wider so the sidewalls and pushed out more but tread is still centered, I am within recommend ranges for tires I use just on the wider side of the range for acouple reasons, it stiffens up the sidewalls, wheels on narrower range tend to roll the sidewalls, handling is better on the wider than narrower, etc..
Forgot to post pics.
The DWS's where more then ready to get off, atleast with the michelins I can rotate them, I do have adjustable camber arms, just not on yet, need to get a fender roller before I put them on.
Found a rub on both sides the larger is on the passenger passenger side, probably from when I drove on a rock pile with one tire and shoved the 2 tires into wheel wells and other 2 tires where off the ground, it is just a rub on the undercoating.
Have the camber arms.
Need to get a fender roller.
Usually I rotate the rears, unmount and flip then remount and so what was in inside is now on outside on opposite side, but can not do that with the dws.
ritous1
09-26-2015 01:27 PM
