Like New 19" Forgestar F14's
Old 07-20-2014, 11:22 AM
grip grip's Avatar
Default Like New 19" Forgestar F14's
I bought these with intentions of installing them on the CL65, but they don't have enough offset for my taste. I think $1,300 is very fair, as the full setup was over $1,800 new, but I'm open to offers.
Front 19 X 8.5 +40 offset
Rear 19 X 10 +48 offset
They include new tire pressure sensors.
Old 07-21-2014, 10:42 AM
rayth's Avatar
Default Re: Like New 19" Forgestar F14's
What kind of spacers would be needed to run them on the CF? I know the stock offsets but with the wider setup not sure what would be needed.. and which of the concave options are they?
Old 07-21-2014, 12:42 PM
Bump for a good seller with a great set of wheels.
Anthony, if I did not have 2 sets of wheels for the XF and 3 sets for my E class, I would be all over these
Old 07-21-2014, 01:59 PM
grip grip's Avatar
Please refresh my memory on the Crossfire's wheel specs. Is this correct:
Front: 18 x 7.5 - ET 35
Rear: 19 x 9 - ET 22
Thanks for the vote of confidence.
Old 07-21-2014, 02:38 PM
grip grip's Avatar
Here's the wheel fitment, front and rear:
Fronts: No Spacer required, and they will be pushed out an extra 8mm.
Rears: Add a 21mm spacer to move them out the same amount as the fronts. I'd use an off-the-shelf 20mm spacer.
Attached Thumbnails Like New 19" Forgestar F14's-fronts.jpg   Like New 19" Forgestar F14's-rears.jpg
Old 07-22-2014, 09:08 AM
rayth's Avatar
Thanks, no issues on the inner clearance on the fronts? I've been wanting F14's and was planning on the upgrade over the winter.. I was planning on keeping 18s/19s but I could get behind 19s all around.. I'm assuming a shorter sidewall on the front to compensate?
hmmm you've got me thinking...
Old 07-22-2014, 10:40 AM
grip grip's Avatar
The wheels easily clear my 8-pots with 390mm rotors, so you shouldn't have a problem at all. As far as the sidewall heights, that would be up to you. Something like 285/35-19 in the back and 245/35-19 up front would look good also IMHO.
Here's an example of the above sizes, which has the rear tires approximately 1" taller than the fronts.
Old 07-23-2014, 08:12 PM
grip grip's Avatar
Price drop and bump combo coming at you! $1,200
Old 07-23-2014, 08:18 PM
I just bought new tires and rims for the E...... Sorry man....those are nice looking wheels... If you get into a drag radial set up and need some 18's let me know... I may have some donors for you once I get them off the E. They are AMG 5 spoke knock off... I think the 18X9.5 would be a nice set up...I will have to check the ET. I am thinking they are 34. Good luck with your sale...they are nice....
Old 07-24-2014, 02:51 PM
grip grip's Avatar
Thanks Doc.
Old 07-25-2014, 10:03 PM
grip grip's Avatar
Sorry to bump so soon, but BUMP. I need these gone. I might have a local bud come over so I can mount them on his car to show fitment.
Old 07-25-2014, 10:07 PM
be careful Anthony. Got my new wheels today and someone had tried to fit them and scratch the daylights out of the hole area and chipped the paint on one. I would say the lazy asses just shoved the bolt up there and used an air gun.... Good luck....another bump for you....
Old 07-28-2014, 11:46 AM
rayth's Avatar
I'm interested but have a questionable employment situation to worry about first before I go and drop the coin
how do you feel about monthly installments?
Old 07-29-2014, 06:30 AM
jediracer's Avatar
My car is lowered with the stockpads still in place. Would I have to "unlower" the car or get different pads? I know 19's will look good because I saw BoilerUp at the dragon a couple years ago and his car was awesome. Any feedback regarding this issue would be appreciated.
James
Old 07-29-2014, 09:06 AM
grip grip's Avatar
James
Sorry, but I don't know the answer to your question. Hopefully some of the lowered guys/gals will chime in.
Old 08-03-2014, 07:39 AM
bump...... Didn't know if you have sold these already. Got my new wheels mounted. Worked out a deal with the seller. The scratches as it turned out were from the drilling machine. They drill their own rims from blanks they get in. They had forgotten to repair the damage before shipping. Worked out good for me. 400 for 1000 set of rims. The 18" rims I have which I think could be used for drag radials were a 44 ET. If you find yourself needing something like this, just shipping is all you pay. Or if I'm trucking your way, that won't even be needed. Or anyone else need a set up like this. They are 8.5x18 40ET, and 9.5x18 44ET. Good luck with your sale.
Added photo of the take off rim...
Attached Thumbnails Like New 19" Forgestar F14's-img_0811.jpg   Like New 19" Forgestar F14's-img_0526.jpg
Old 08-03-2014, 09:54 PM
grip grip's Avatar
$1,150 plus shipping!
Old 08-04-2014, 08:35 AM
Wow, great price for some nice looking wheels. I would be all over these but I'm leaning towards chrome rims for my SSB SRT6...having a hard time envisioning black rims on it.
Old 08-04-2014, 09:20 AM
James
James, I have never had 19" rims on my car, so I can't comment. I had 20s all the way around on the black one and an 18/20 stagger on the gray one...
Old 08-06-2014, 10:47 PM
grip grip's Avatar
Paint them for $30 in your garage.
Quick Reply: Like New 19" Forgestar F14's
