Center Cap exact size?
Old 12-15-2014, 01:41 PM
MiamiTVR's Avatar
Default Center Cap exact size?
After a couple of searches I have found lots of dialogue and subjective opinions regarding the aesthetics of small center caps that expose the lug nuts versus the original size that covers it.
What I have not been able to find is what is the exact size for that small cap. I have a Chinese seller on the other end, communication is sketchy and returns would be a hassle.
If someone could provide the exact size in mm it would be greatly appreciated.
Thanks in advance.
Old 12-15-2014, 03:41 PM
Default Re: Center Cap exact size?
on the SRT6 wheel, the inner hole is 70 MM, the area to cover is 83 MM
Old 12-15-2014, 04:33 PM
MiamiTVR's Avatar
That is much appreciated.
Old 12-17-2014, 03:08 PM
MiamiTVR's Avatar
To confirm this one at 75MM
http://www.ebay.com/itm/161472014415?_trksid=p2060778.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
and this beauty at 56MM
http://www.ebay.com/itm/4x-56mm-Auto-Wheel-Center-Hub-Cap-Emblem-Badge-Decal-for-AMG-A-B-C-E-S-R-series/321468581755?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D27538%26meid%3D483b7f7a6bcc4d89ba68f4b7b64535b7%26pid%3D100005%26prg%3D11353%26rk%3D3%26rkt%3D6%26sd%3D111346723055&rt=nc
will not work despite how much I really want them to?
Old 12-17-2014, 03:34 PM
75 MM just might squeeze into a 70 mm hole depending on how the plastic fingers on the back work on the first one, the second one you show is just stickers.
For a lousy $15, I'd say try the first one.
Let me know, I might get a set too for when I finish with rebuilding the set of SE wheels I have.
The OEM caps I have for these are pretty bad.
( SE wheels are SRT6 wheels that have all but the polished spoke surface painted metallic gray )
Old 12-18-2014, 10:32 AM
texas t's Avatar
Post Re: Center Cap exact size?
I got the amg caps on my srt6 wheels, had to use some glue to hold in place, they are to small for hole. I tried bending tabs out but was unable to get tight fit so glue and held in place with tape until dry. Yes they must be remove when changing tires easy to get off and put back on. The outside diamater will cover hole nicely.
Old 12-18-2014, 07:26 PM
texas t's Avatar
Also there is a round stick on mirror that fits perfect over ctn hole in wheel
Old 04-21-2015, 12:57 AM
So 70mm centercaps would fit the inner hole. And 83mm would be needed to replace the SRT-6 lugnut cover centercap?
There are lots of options for 75mm I see on eBay.
What size did you go with? Must of been smaller then 70mm.
So for confirmation, a 75mm Mercedes centercap will fit the centerbore of a SRT-6 rim? It will just be a tight fit? My SRT-6 has MErcedes centercaps already, but they are fading and look like crap.
This looks just like them:
http://www.ebay.com/itm/NEW-SET-OF-4-MERCEDES-BENZ-YR-1989-2014-75-MM-WHEEL-CENTER-CAPS-HUB-CAPS-/321496994552?hash=item4adab6d2f8&vxp=mtr
onehundred80
08-12-2015 03:08 PM
BrenLW
08-05-2015 04:53 AM
WindRestrictor
07-30-2015 03:42 PM
tom2112
07-28-2015 08:12 AM
MSCrossfire42
07-27-2015 07:59 PM
Quick Reply: Center Cap exact size?
