Bolt Pattern for Crossfire wheels
Re: Bolt Pattern for Crossfire wheels
[QUOTE=dljones;876169]Sounds good. I appreciate your time and since I want to get some new factory rims, I may just put the old ones on the front to check out. I was also concerned with lug pattern and interchangeable rims size so thanks for your insight. I'll let you know how it goes. Thanks again.
Definitely keep 18's on the front. (I went a 1/2" wider)
18's on the back DO fit, but they look super tiny. It looks like 20's will clear.
Try and stay away from 19's if you can. that tire size is going the way of the Dodo.
Just find some rims you like with 18's in the front with 5x112 bolt pattern
and make super sure they have 20's with a 5x112 bolt pattern
, that's the real trick.
