not stabile
Re: not stabile
By any chance is your BAS/ESP light on? If the wheel speed sensors are throwing bad data it could cause the ESP to make micro adjustments and you to feel a wobble as a result. This is more common in the rear than the front. Do you have a sense for which end isn't tracking properly? Front I might check tie rods. Rear I'd check tires first then wheel sensors.
