SRT6 Brake Upgrade (FINALLY)
Re: SRT6 Brake Upgrade (FINALLY)
Originally Posted by HDDP
Dan, you must have misunderstood my other post... Yes, I am aware that any cross drilling or slotting needs to be done on a pristine rotor... And by the way, I've been doing this stuff for over 25 years now... Thank you for your concern incase I overlooked something...
HDDP, Thank you for doing all the leg work for us. I may wait a bit and try to find some of the parts cheaper and do it too.
Not that the prices are that bad I just like the challenge.
How does it feel for street driving? Is it a noticeable difference?
I have no track time yet. Hopefully this spring.
You won't be able to find a system cheaper unless you rape some parts from a totaled SRT6 or other MB cars that share the same parts... There are 6 MB cars that use the exact front calipers, rotors and adapters as the SRT6... If you purchase the parts from MB, your costs will be 32% higher than purchasing through DC...
And you really don't need to spend the $$$ if you're just driving the car on the street... The OEM brakes are terrific for daily driving...
on
I love the way the new calipers/rotors fill in the front wheel though. It makes the stock units look positively anemic by comparison. I think a few years down the line, this is going to be one of those "must have" mods for us base/limited owners. I know it's on my short list.
Originally Posted by bobs
Lookin' great, HDDP! I can't wait to see how they perform on the track. One more question fro you: Did you happen to weigh the SRT-6 parts before you installed them? I would be curious to see how much more the SRT-6 parts weigh than the stock ones. My concern is that the increase in un-sprung weight might cause the front end to feel a bit unsettled because its overloading the spring/shock combo. I dunno, it might not amount to anything at all but you never know...
I did the "hold it in your hand" weighing method. And yes, the SRT6 front rotors are probably 10 lbs heavier and the caliper is maybe 2 lbs more...
Look how silly small the OEM rear rotors look now... That's why I was originally concerned about bias... They're barely visible... I like your anemic comment, a perfect term for it...
I'll let you know how they work in the next few weeks... I'm still breaking them in... and will have to change the pads once I season the rotors... I'm going back to the Porterfields if they make them for this size...
Now that I know the swap-out works properly, I have another set of rotors that I'm going to have milled and slotted. And I already ordered the rear SRT6 set-up and should take delivery in the next few weeks...
Considering the Brembo Big Brake kit is $3,500 +/- This was only $1,200 for the fronts and should be only $800 for the rears... Not a bad way to upgrade the brakes IMO...
PS: I have a set of Limited calipers and rotors for sale... LOL Cheap !!!
Back to the subject, those PN's are incorrect. A big giveaway is there is a left and right side PN.
http://www.mbwholesaleparts.com/fmpc...assisShort=170
Choose a category then change Select Baumuster to one of the following:
170.447 for 1996 SLK 230K
170.449 for 2000 SLK 230K
170.465 for 2000 SLK 320
170.466 for 2001 SLK 32K
For base or limited, I'd select 170.465
For the SRT-6 I'd select 170.466
By the way, The rotors and calipers are the same on my SLK32/(C32) and SRT-6.
the slk32/srt6 are both; 330x46.4mm
the C32 AMG; 345x47.5mm
the C55 AMG; 345x47.5mm
so either your incorrect or the Brembo site is whacked. Also the C32 has a different rear differential which is another give away that the C32 is a beefier car.
Originally Posted by Maxwell
the first two pics......
C32 [203.065] brake rotors and calapers
A0014201983 2002-2005 (203.065) (112.961) Brake Caliper, Right Front
A0014202083 2002-2005 (203.065) (112.961) Brake Caliper, Right Front
A0034239698 2002-2005 (203.065) (112.961) Brake Caliper, Left Rear
A0034239798 2002-2005 (203.065) (112.961) Brake Caliper, Right Rear
A2034210912 2002-2005 (203.065) (112.961) Brake Disc, Front
A2104230812 2002-2005 (203.065) (112.961) Brake Disc, Rear
yes those caliper are the same but what model year is that AMG C32 from? there was a recent brake update on that car where the front rotors where enlarges .42" or abouts, and it has a different caliper.
"Mercedes-AMG’s racing experience shows even more in the C32 AMG’s competition-derived braking components. The newly developed braking system is always ready to deliver outstanding stopping power. Front brake disc diameter has increased by 0.43-in. compared with the preceding C43 AMG model, providing the best possible basis for short braking distances and fade-free performance. Cross-drilled, internally vented, 13.6- x 1.2-in. brake discs are used at the front, with internally vented 11.8- x .9-in. discs at the rear.
In preliminary brake testing from 100 km/h (62.1 mph), the new C32 AMG comes to a complete stop after just 118 feet. Naturally, the standard anti-lock braking system with electronic brake force distribution, the Electronic Stability Program ESP, Brake Assist and the traction control system have been specially programmed to suit the dynamic performance of these cars. "
Did I screw up...
Roty135
17
10-11-2018 10:11 AM
