Originally Posted by Louie K
He doesn't know, I assumed that was the problem due to the test drive I had with the vehicle. All it said, when I was in it was "Check engine" I didn't see any codes.
The way you access the DTC's is through the OBD port and a scantool... You won't know what is causing the CEL until you read the codes through the scantool... So, until that happens I can't help you...
