Old May 5, 2004 | 09:34 PM
Heb80's Avatar
Heb80
Default
Originally Posted by James Sonne
I weighed the wheel and tire when I took the wheel off to get to the transmission fluid cap one day last summer. 22 pounds.
A quick search online found that an RSX wheel by itself weights around 17lbs, not bad for a 16" wheel.
A crossfire wheel may sound heavy in comparison to an RSX wheel, but when you consider that the facial area is 40% larger, the circumferance is 20% larger, and the width is 30% greater, not to mention the wheel is designed to handle very low profile tires (wheel has to absorb more impact), and designed to handle high speeds, the 29lbs i'd say is within reason.
