Originally Posted by 04Fire
The only question I have is on the front there is a cover over the top bolt do I just pull it off? I don't want to have to drive to the dealer to buy a stupid cover if I break it.
You think I can do it without removing the wheels?!
Thanks Andrew!
04Fire,
The black cover on the front shocks will pull right off - no tools required.
#17 wrench for the nut and a #6 or small crescent wrench for the shaft (to keep from spinning) for the OEM shocks, not sure of the Koni's.
Tighten until good and tight. It will be easier with the wheels off. Did my left front Sat - so still fresh in my mind.
Good luck with the Koni's.
