Originally Posted by 04Fire
I thought it was that easy...
When I was cleaning out all the glass in my trunk I removed the side carpets and noticed just one bolt on top and when I went underneath there was one more bolt.
The only question I have is on the front there is a cover over the top bolt do I just pull it off? I don't want to have to drive to the dealer to buy a stupid cover if I break it.
You think I can do it without removing the wheels?!
Thanks Andrew!
brian is correct... that plastic cover/cap just pulls off to access upper bolt. the cap will need to be trimmed down once koni's are installed in order to reuse it.
i did not remove my wheels when installing shocks ... but would probably make it easier... but still not too bad doing the install with them on.
ps - i shipped the shocks out on wednesday morning.
