Old Nov 6, 2007 | 02:59 AM
  #166 (permalink)
antonio311's Avatar
antonio311
Default Re: WOW ... stop the rust while you can ...
No the weatherstripping isn't absorbing moisture like a sponge, the water may be inside of the stripping (the inside is hollow to allow airflow so it stays dry). What we are talking about is the back side against the metal holds moisture. Just clean the stripping with windex, and allow it to dry out in the sun (detached from the door) for a few hours. Also make sure the inside of the door where it touches is also clean and dry. When you get a chance seal the inside of the stripping channel with por 15 and you'll be protected for a long time with no worries. And don't forget to enjoy your crossfire!!!
