Interior Lighting
Dec 7, 2007 | 04:19 PM
permalink
maxxm
Dec 2004
1,168
Arizona [85255]
Re: Interior Lighting
Quote:
Utah12
I heard that 44 mm is too long for the trunk, that its more like 36mm. Also with the 9 LED Blue will the cargo area be bright enough to see at nite. Thx so much!!
I used exactly the bulbs noted above and needed no resistors because everything worked fine and did not trigger the "bulb out" indicator. I believe the bulbs for the trunk light areas may be different for roadsters than for coupes. The 9 lens LED in the coupe trunk compartment does not produce too much light, but it is adequate at night (unless you're planning to read a book or something like that).
I have had these bulbs in the car for over two years with no problems at all.
maxxm
View Public Profile
Find all posts by maxxm
