Old Dec 15, 2007 | 08:40 PM
BrianBrave's Avatar
BrianBrave
<--- Huge Horsepower
Default Re: Removing the Calipers from the Rotars
Originally Posted by Sidez
Alright guys what I am trying to do is remove the calipers to install the rotex gold brake pads.. to pain the caliers and to install stainless steel brake lines..
HDDP before you attack me with the search button features I have tried and have stumbled upon Andrew's Guide, but that is a guide for someone who pretty much already knows how to do it.. I don't know what piston clips are... beyond other things..
If anyone can guide me through it.. it would be of much help...
Do I remove the calipers from the rotars first? Do I remove the brake lines from the calipers first? 2 brake lines are attached to the calipers.. I was able to get one loose... the one behind the caliper i am unable to remove...
o and if it matters I have the SRT
Thanks in advance
-Sidez
Are you going to remove the calipers to paint - or leave them in?
I pulled mine out, scuffed and painted. The brake pads were a cinch to remove and replace with the calipers on the bench.
I can write up the procedures I used from memory if it will help.
https://www.crossfireforum.org/forum/showthread.php?t=17511
