Old Jan 26, 2008 | 06:06 AM
Steve Hellums's Avatar
Steve Hellums
Default Re: Moving The HE Forward To Add Cooling Fans
Originally Posted by HDDP
Great show & tell thread Steve... Even if it's an experiment, the terrific part is that you had the intelligence and motivation to do it... And share the process with the forum...
I'm sure that your concept will help the performance of the car...
Thanks HDDP. I have a question that you would probably know. What tells the I/C pump to come on, tempeture or does it run when the car is running? I could not tell if the pump was running or not yesterday. And another question I had too, I was wanting to make sure the sending unit was not leaking before I put the front bumper cover back on. Since both cooling systems share the overflow resevior, shouldn't the pressure be the same in both systems even if the S/C system is not up to a higher operating temp?
