Old Mar 24, 2008 | 11:19 AM
SRT6 Gang Member's Avatar
SRT6 Gang Member
THREE 6S
Default Re: What are your 60' times???
Originally Posted by waldig
Well Iam trying to evaluate the car with the Needswings intake and the porting / polishing that I did recently. The best way I can do that is with the 60' times before the track opens, and it warms up. With the limitation of 60 mph or so, my Passport G meter and I have been getting 1.95 to about 2.05 times and wondered how that compares on Factory street tires to other SRT's. Its still very cool weather and it is hard to not spin which looses time.
I have the Phantom grip and factory tires but must start at about 1200 - 1400 rpm and roll out to keep from slipping (blowing off the tires, cause once they slip they are flat gone till you get all the way out of it). The traction control is off, as that has a habit of killing the throttle and introducing a BIG bog like effect. When I get the LET 181 pulley and install the heat exchanger I will try it again to see if there is a measurable difference.
Trouble here is that we only have 1/8th mile tracks and they are not open for test and tune events yet. Figgured that I could get some other peoples numbers for comparison in the mean time, thanks
I have been to the track twice making a total of seven passes. My best 60ft was 2.185, stock from top to bottom.
