Lets make some sense of all this;
These cars, like virtually all new cars these days, need no specific break in period, however, like all other cars, the engine does losen up a bit, and start to run a little smoother when a few, 8ooo? or 12000? or whatever thousand miles have been done. The ECU is not programmed to interact with this normal bedding in process and will not change anything as it happens, and has'nt the intelligence to know when it has happened. The ECU does regognise pedal movement and works to provide the smooth docile response.
Most new cars have "fly by wire" throttle, its been around since the miidle 1980's. The advantage is a lighter, smoother accelerator pedal as theres no friction from a cable, and no maintainance needed. The disadvantage is the lag time caused by the slow signal. The throttle response is designed to be tame in order to make it drivable, predicable, easy to drive, for the "average" driver. But this can be cleared by the re set process, but the lag time will remain, you cant get rid of that unless you go for the SBooster. My wife will not drive mine since I fitted the Sprint Booster as it has become more fierce and harder to drive, especially in traffic. She was quite comfortable with it before. A few days ago I sat at the controls of a nice 1979 Aston DB5, no fly by wire here! 2 throttle cables and two massive carbs. Engine reved instantly, awsome power, and a complete animal to drive!
Hope this helps,
Steve
It does help Steve but I'm still curious as to how long does it take driving "docile" to lose the more aggressive throttle mode and why not have the response go back the other way when you start to drive aggressively. Why only tick down and not tick up also? We shouldn't have to reset our computer all the time to get optimum performance. I don't know about you but I will always wonder what "mode" I'm in at the time and I shouldn't have to do that.
Are you saying that once we clear out the mode for the "average" driver and reset the throttle it will stay in the more aggressive mode?
This is all starting to make my hair hurt
but I'm still very curious. Thanks for the posts everyone.
I am thinking of emailing Chrysler about this issue. It would be interesting what kind of response and answers I may get.
P.S. Steve, Love the UK & Chicago blues.
