Old May 18, 2008 | 11:35 AM
mikecrossfire's Avatar
mikecrossfire
Default jex chip install
purchased jex smart chip to install on 2008 xfire---instructions are really
geared to hook up to vehcile with separate iat sensor---08 xfire has maf
and iac sensor together in same harness----it appears that both sensors share pin 3 (brown wire) as common ground and the iat sensor wire is pin 1
(yellow with green tracer)-----no matter how i instaqll the 2 chip wires the check engine lite will come on and the electric fan also comes on immediately after starting. anyone have suggestions---would be much appreciated---maybe this is what i get for going for a cheap, quick fix
