Old Aug 3, 2004 | 06:11 PM
C_Plunkett's Avatar
C_Plunkett
Default
Originally Posted by Bullseye
thaks for the resposes. Now if i have a set of 5x100 42 offset would that fit on this car? they are a universal wheel ADR something or another. They are 17's if it makes a difference.
No. The bolt pattern (5x112) must match exactly. Offset can vary some. It will just make the wheels stick out more or set in towards the center of the car depending on the way you go (assuming the wheel width stays the same). The issue then becomes whether the increase (or decrease) in offset will cause any rubbing problems.
