Thread: Resetting TPMS
Old 09-10-2008, 12:28 PM
CrossfireLTD's Avatar
CrossfireLTD
CrossfireLTD is offline
Cool Re: Resetting TPMS
If you do have to resort to consorting with a dealer:
as far as I can tell, when they "reset" the TPMS system they "tell" it what PSI setting at each tire to expect. Am I wrong?
Anybody?
So make sure they do it right, as it is preset to warn at a 10% psi drop.
(Set for 36 psi rear and will alarm @ -10% (3.6psi drop=32.4 PSI).
While done with the tire @ 33 PSI and .6 PSI later:
Warning light.
Is this the way it works? Or am I full of crap?
Max.......you are correct (and not full of crap ), but I believe it is a 25% PSI loss (approx. 8lbs.) and this can be a combination of tires, example 1 tire has a 4lb. loss and another with a 4lb. loss will trigger the TPMS.......as told to me by my trusted Xfire Tech.
