Old Nov 17, 2008 | 01:29 PM
waldig's Avatar
waldig
Default Re: HELP, Math new ENLARGED MANIFOLDS
We are dealing gasses and they are compressable. 1 PSIG is full to some extent, but then a cyclinder filled at 5 PSIG would be filled 1.25 times as much as 1PSIG ( Please Note: PSIG and not PSIA). The pressure is just a measure of the amount of gas in a given space, more is more, assuming constant temperature for a given mixture of gas(es).
I have not decoded the bottle neck point and Guess that you may be referring to the head assembly of the engine. It is that at times but they open alternatley 3 times per revolution of the crank. ! ?
most grouchiest ???
Re.
Boyle's law (sometimes referred to as the Boyle-Mariotte law) is one of several gas laws and a special case of the ideal gas law. Boyle's law describes the inversely proportional relationship between the absolute pressure and volume of a gas, if the temperature is kept constant within a closed system.[1][2] The law was named after chemist and physicist Robert Boyle, who published the original law in 1662. The law itself can be defined as follows:
For a fixed amount of gas kept at a fixed temperature, P and V are inversely proportional (while one increases, the other decreases).[2]
Woody
