bolster wear
BKH,
In the first few weeks I noticed that one spot on my bolster wasnt' exactly wearing, but it had a sort of a wrinkle to it. It's basically where my right butt hit's the bolster when I slide in.
I'm about the same weight as you, 5'8". For that reason, I have to keep the seat far enough forward to comfortably drive that it's next to impossible to slip in without seriously rubbing the bolster.
I began the practice of turning backing in a bit with my left hand behind me on that spot on the bolster, then twisting and sitting in.
THEN I just realized this weekend something you all probably already know, but I haven't read the manual end to end.
With the door open, the electric seat adjusters work whether the car is running or not..even if the key is not in the ignition. They do NOT work if the car is off and the door is closed.
When I stop the car now, I adjust the seat back far enough that I don't have to put too much or any pressure on the bolster for ingress/egress.
If I forget, when I open the door I can take a few seconds and set the seat back before getting in. Once in, I can leave the door open and move the seat back into driving position, close enough to depress the clutch to start.
You could also fiddle with your driving positon ala the seats and the telescoping steering wheel.
OR you can get some sheepskins.
Good luck.
