mounts with a bracket/bolt setup and also with a super slick slip-in alignment tab
included with the kit will be
catch can itself
hoses
clamps
2 double male aluminum line conversions
vac cap
nut/bolt/washer setup for bracket
drain
1 pair (2) of our intake manifold gaskets (as install is much easier if you remove the intake manifolds)
TIG welded 6061 billet aluminum
all aluminum hose connections are double flared for a sure seal.
pricing will be...
without powdercoating $108+s/h
with main can powdercoated $128+s/h
we have a batch of 30 in production now, almost half of them are completed, the other half are in their final stages so they should be ready to be dropped off to powdercoating late this week in one batch. if you wanted to paint/coat yours yourself please let me know ASAP before they all get dropped off.
externally teflon coating them to match our Intake manifolds is available also but will be $14 more then the powdercoating.
